Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Unread 30-04-2008, 16:26
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: How much torque can the Dewalt Trannies take?
I'm not necessarily the best person on this subject but as far as I know we don't have any real numbers on the limit of the dewalts. Though the failures appeared to have similar simptoms, we managed to cause a different failure almost every time. This was running two cims through the dewalts on a 6 traction wheel drive (6 inch andymarks) with the center wheels dropped.
edit: originally we did break a few drive shafts but then we managed to chase the failures into the transmissions themselves
Team RUSH Alumnus and Mentor, Mechanical Engineer
Last edited by Josh Fox : 30-04-2008 at 16:28. Reason: further input and spelling, grammar and such
Unread 30-04-2008, 17:01
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Robodox also used 2 CIMs driving 1 Dewalt in a setup very similar to RUSH.
We used a 3:1 belted reduction from each CIM to the input of the Dewalt. The output of the Dewalt directly (via a coupler) drove the center wheel of a 6WD 1/8" center drop drive train.
(RUSH used a slightly lower geared reduction before the Dewalt.)
Some observations:
The Dewalts are planetary transmissions. As such, they have a considerably lower efficiency than a gearbox using only spur gears. (They also take up less space for the same reduction.)
You've got to make sure you hold the actual transmission really well. The original housing from the Dewalt drill is best for this. We found that our major point of failure was the actual transmission spinning inside the housing (we didn't use the entire drill casing - our mistake!) We found this out in testing and never had a problem in an actual match.
Shifting is not always smooth - especially using a single servo to hit all three gears. It is possible to fail to shift - leaving you in neutral unless you quickly shift back to your original gear. Shifting is easiest when under power with a light load. Shifting the Dewalts was our major problem this year. At one point, we thought we had broken a tooth on one of the gears in the Dewalt, but after taking it apart, we couldn't find our what was wrong. Our best guess was that it wasn't shifting completely for some reason. RUSH quickly figured out that they were better off just keeping them in a single gear for the 2008 game.
We have made an alteration to the setup in the NBD paper. In NBD, the planet gears that mate with the gear on the drill motor are removed along with their supporting pins. Then the sun gear is reamed out to be fit onto a shaft. Instead of making this alteration, it is very possible to use the 4 pins that hold the planet gears to drive the sun gear by making a simple coupler. No machining of the Dewalt! This setup worked well for us the past two years and is especially useful when mating two motors to the Dewalt. (Any problems observed with our robots were from other sources.)
In the end, the difficulty in mounting the completed gearbox and the reduced efficiency as well as the costs required for additional hardware (belts, pulleys, bearings, etc.) have turned us away from the Dewalt for the near future.
Andy, the check will be sent soon.
-Mr. Van
Coach, Robodox
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
Servos - How much can they lift? John JediMaster Electrical 23 31-01-2004 19:03
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
