Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > CAD
Unread 29-04-2008, 07:51
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
Exclamation my team needs crab/swerve pod cad files
My team want's to go with a crab/swerve drive system next year, and we want to start experimenting over the summer. Would anyone be willing to e-mail us some cad files of thier systems? Prefferably for Autodesk Inventor. Just post here and I'll send you a pm with my e-mail address. Thank you!
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
Unread 29-04-2008, 07:53
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: my team needs crab/swerve pod cad files
although im sure someone will give you it i think you should look through the gallery as many CAD's of crab drives have been posted
Unread 29-04-2008, 09:29
REVving up for a new season
FRC #2848 (All-sparks)
Not to come off the wrong way, but is there a reason you are looking for someone else's system instead of designing your own? I can understand the reasoning for wanting to look at other people's designs but asking for CAD files might cause too much temptation to just build what they have. The other thing is that when you just receive CAD files from someone you have no guarantees that the parts are right. There are plenty of times that by the time you are done building your physical parts don't match the CAD.
IMO the best thing to do would be to look at lots of pictures of systems and then start from scratch. It may take longer than just getting some files, but I can guarantee you will get more from the experience.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 29-04-2008, 10:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
CraigHickman has a good picture of a crab module and a drive train assembly on his site. You could also PM him to ask him how he did some of the more intricate work.
http://www.xtremefury.com/craig/
I too highly recommend that your team does the CAD from scratch. Use a few pictures as reference, but do your own design. Knowing every nut, bolt, washer, sprocket, chain, and spec of dust you put into your drawing will make it that much easier to come up with design improvements. If your team is new to CAD, I would recommend doing the tutorials first, then doing a simple aluminum frame. Then from there you can experiement.
As always, many of the FIRST motors, transmissions, pneumatics (etc) are already available at www.firstcadlibrary.com
GitHub
Unread 29-04-2008, 11:04
Try a search in CD-Media. Pictures: "crab" and "swerve" turned up plenty between them. Modules, photos of crab and swerve drives, CADs, individual modules...
I'm not sure if anyone's done a paper on that type of drive, but someone might have.
Unread 29-04-2008, 13:23
AKA: Will Crabtree
all we want the cad files for is to see the pod without anything obscuring the view. we just want to see how some people put their pods together before we design our own. we understand the problems of building something off of a cad file. our cadders will sometimes decide to do things... well, not how they shoud be on the robot
Unread 29-04-2008, 13:34
CraigHickman
Posts: n/a
Wow, I feel honored to be mentioned...
But anyway, sharing CAD is a tough issue. I normally don't share it unless it's someone I trust, but even then I put in a "security" measure in order to make sure they're doing their homework. Some dimensions will have been slightly changed, not enough for aesthetics, but enough that any attempt to make the part will fail miserably, or will be hell for the machinist.
As for designing your own, I can send you some renders, as well as answer any questions you've got. Please feel free to AIM me any time, or PM me with any questions. Oh, and that old CAD gallery is WAY out of date.... I ought to link the new one...
Unread 29-04-2008, 14:25
Ummm...no offense but this seems like a waste of time. The way I see it if you are not willing to share your CAD that is one thing, but messing it up on purpose so it won't work seems like a bad idea. Especially for high school students calculation center to center distances for gearboxes or any of the other precision required dimensions can cause problems even if they design them from scratch. I think it would be better just not to make them public, because once you release virtual files you no longer control where they go and a 3rd or 4th party person who may get them may not even think that they aren't complete. Yes it would be a lesson to learn for the person who just tries to copy but won't you still feel bad when a robot running your design fails miserably on the field....I know I would.
As for seeing unobstructed views of the CAD to get designs from you might have people use auto desk freewheel. http://freewheel.labs.autodesk.com/index.aspx
Unread 30-04-2008, 01:12
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Hi Will,
Good idea taking a crack at a Swerve drive during the off-season, there is a lot of development involved in something like this.
I don't have Inventor, we do our modeling in SolidWorks. Check the attached ZIP file for a STEP assembly of the Robowranglers 148 - 2008 Coaxial Swerve Module. (The STEP file should import cleanly into Inventor.)
This module was heavily inspired by the Thunderchicken 217 - 2002 & 2003 designs. (Thanks Foof!)
Let me know if you have any questions.
I'm happy to help, and always sympathetic toward a college FIRST team!
Regards,
John
PS - All the dimensions are valid; this is exactly as we built her.
PPS - Don't do a swerve drive for a competition robot.
Last edited by JVN : 30-04-2008 at 01:21. Reason: I like 461, had to add the "PPS".
Unread 30-04-2008, 01:37
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Great files, John! Quick question about that module: What type of bearing are you using for the large turntable? (and where does it come from?) I would have thought that a design with a single bearing like that would put enormous side loads on the bearing that it couldn't handle. Did you have any problems with it at all?
I think we'll take that advice!
Unread 30-04-2008, 08:54
James Tonthat James Tonthat is offline
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Thanks John!
I was trying to figure out how one of the bearing sections worked and what kind of bearing was used (thrust or ball.)
Edit: Err, nevermind
Unread 30-04-2008, 11:49
JVN JVN is offline
@JohnVNeun
Yes there are enormous side loads on the bearing, but it handled it fine. The practice chassis deformed but the bearings are fine.
The swerve bearing is a 2" ID, 2.5" OD, 0.25" THK bearing.
It is a KAYDON bearing P/N KA020XP0. You can buy it from any KAYDON distributor. (We got ours from Motion Industries.) If you say you are a FIRST team you can get a discount.
Paul Copioli was the one who recommended it to me, as it is used commonly on the real robots he works with.
After we started production on the swerve parts, I got cold feet. I have never done something like this before, and I am a pessimist by nature. I called Paul up and asked him if this bearing would be able to survive the heavy shock loads caused by our application or if we needed to support the base of the swerve module. He just laughed at me.
These bearings held up great; they were perfect for our application.
It was important to make sure that both the inner race and outer race of the bearing are WELL captivated. You can see in our cross section how we hold the bearing in place. (See above post.)
This may not be the best way to do things, it just happens to be the way we did it.
Hope this helps!
Regards,
John
Unread 01-05-2008, 19:00
Wait, so that's a 200 dollar bearing?
Unread 02-05-2008, 11:57
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Being able to use a single bearing to mount the swerve module to the robot was probably deemed worth the expense. I believe a normal application would be to have a pair of bearings one to take axial and radial loads, and one to take radial only. This would deal with the moment generated at the mounts. Please correct me if I'm wrong.
Simple Swerve/Crab Rob2713g Technical Discussion 4 20-03-2007 19:00
Swerve/Crab Rob2713g Technical Discussion 5 12-11-2006 22:05
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
Crab/Swerve/Synchro Pics Joe_Widen Technical Discussion 6 15-04-2006 20:54
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
