Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 30-04-2008, 19:49
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
1557's gearboxes
we finished our semi custom gearboxes wich we made out of kop am's all we did was change the gears around and remove some stuff
we ended up with a 1:3 (induction?) with two cims on each side we will achieve 23+ fps or more depending on the sprocket sizes and wheels we choose
Unread 30-04-2008, 20:08
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: 1557's gearboxes
Any pics? (I think the word you are looking for is reduction)
Unread 30-04-2008, 20:19
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Induction is something that has nothing to do with gears. It is a property of coils of wire and refers to how much a particular coil resists a change in the flow of current in a circuit. It is measured in Henrys and is really quite interesting.
http://en.wikipedia.org/wiki/Electromagnetic_induction
As for your gearbox I think I remember other teams using this as well to get high reductions but I can't remember any numbers.
Unread 02-05-2008, 13:49
gorrilla's Avatar
AKA: adam spears
well i couldent think of any word for what it did
bbecause for every one turn of the motor the output shaft spins 3 times
Unread 02-05-2008, 14:11
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I hope you mean for every one turn of the shaft, the motor spins 3 times... otherwise, your speed will be a little higher than 22 ft/s... like 220 ft/sec.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 02-05-2008, 14:16
CraigHickman
Posts: n/a
Now now, kids. Let's back off a little.
Can we see some pictures of these gearboxes?
Unread 02-05-2008, 16:19
AdamHeard's Avatar
Lead Mentor
They probably are just using a single stage (14:50) of the AndyMark Gearboxes.
And Craig, why are you calling people kids, you're a kid yourself.
Unread 02-05-2008, 17:22
CraigHickman
Posts: n/a
It's an expression that I use a lot when talking. I keep forgetting that text doesn't convey tonal choice, or inflection at all. Oh, and body language.
Unread 02-05-2008, 17:37
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Team 1726 did the same thing with our transmissions, and I believe a lot of other teams did the same thing, too. It's simply a matter of flipping the aluminum (output side) plate of the Toughbox over, so that the output shaft can sit where the idler shaft used to be. The only modification that needs to be made is that the output plate needs two new clearance holes for the motor shafts so that they will fit (easily done with a drill).
I asked Andy Baker about it, and he said it wasn't an intended modification. It sure was nice of him to make those gearboxes symmetrical, though!
Oh, and the new reduction when you do this is about 3.57:1, if I remember correctly. Attached is a crummy picture of our set up...
Unread 02-05-2008, 18:03
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
...if it could move at all. It will be unable to move on anything other than a downhill slope.
--Madison--
...down at the Ozdust!
Unread 02-05-2008, 21:05
Fidgetting
I don't know, I bet that if you over volted the CIM enough you could get it to move for a few seconds. You know... before the motors burned up.
Unread 04-05-2008, 17:31
gorrilla's Avatar
AKA: adam spears
yeah i ment the shaft turns 1 for every three times the motor does.. i was really tired from sailing.
oh and ill get the pictures thursday when we meet again.
ps. those pictures look nothing like our gearboxes
Finding Gearboxes Armando Gonzalez General Forum 5 12-01-2008 22:28
Gearboxes Evert Technical Discussion 19 10-01-2008 18:47
Gearboxes Calvin_1631 Motors 2 20-02-2007 19:40
Assembled Gearboxes? alexrobotics Motors 10 08-01-2004 01:01
Drill Gearboxes archiver 2000 1 23-06-2002 23:09
