Go to Post OK, I may have heavily influenced their decision, but I would never kill a mentor for not choosing an event I was planning... maim maybe, but never kill! :D - KathieK [more]
  #31   Spotlight this post!
Unread 03-05-2008, 00:55
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Re: pic: 1726 NURC robot prototype
We got some 3200mh batteries lipo from tower hobbies
http://www3.towerhobbies.com/cgi-bin...&I=LXMDN3&P=ML
the link is not the right battery but it is the same brand
The three blade reverse pitch, pusher prop
http://www3.towerhobbies.com/cgi-bin...?&I=LXAPX4&P=7
and then we cut it to 4inch diam. to fit in abs coupler
Faridodin "Fredi" Lajvardi KD7WKD
  #32   Spotlight this post!
Unread 03-05-2008, 00:56
AKA: Ledge
Hey do you know where to get a rack and pinion set. We are needing a way to extend our arm in and out, screw drive is just not cutting it. We prefer plastic, but small brass will work as well.
  #33   Spotlight this post!
Unread 03-05-2008, 00:59
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Stock Drive Parts/Sterling Instruments is a good place. They're reasonably priced and have a big selection to chose from. Just be careful, we've gotten some bad stuff from them before.
Team 1538 / The Holy Cows, 2005-2016
  #34   Spotlight this post!
Unread 03-05-2008, 01:15
AKA: Ledge
Thanks Jon.
  #35   Spotlight this post!
Unread 03-05-2008, 02:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I wonder if you could use the vex rack and pinion parts? you'd have to make a support thingy for it, and the stuff that it's made to bolt to is all steel (or aluminum), but you might be able to make something from plastic.
http://www.vexrobotics.com/vex-robot...gear-kit.shtml
also Lego comes to mind, I think they have some short stroke rack and pinion setups in some of the car sets? My son Steve might know, he still plays with Legos (and he's in college now)
  #36   Spotlight this post!
Unread 04-05-2008, 02:55
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We made a quick little robot tour of our progress to date.
http://www.youtube.com/watch?v=IVfcqfdcpX8
We went on a shopping spree today and bought parts for the other additions to the team ( ) along with our new lighting system, some small 3watt apparently pre-watertight lights. Also, we finally took the 'bot for a test night swim and everything worked out perfectly, including the new "appendage" used for picking up objects!
I'll try to get some image up soon in the gallery, but until then you can check out the video
  #37   Spotlight this post!
Unread 04-05-2008, 10:34
run the trap!!!
Team Role: Human Player
SDP-SI also has plastic and brass racks.
-Philip J. Fry
  #38   Spotlight this post!
Unread 04-05-2008, 13:23
AKA: Ledge
Thanks! We order some today!
  #39   Spotlight this post!
Unread 04-05-2008, 13:36
AKA: Ledge
Where is the night video? You guys are doing great!
We are in the process of making the new ROV for this year. We are calling it Amanda, Tell you the story later. Basically a slightly improved version of last years. We are also making a second ROV much smaller as an assistant. We will post pics soon. We hope to be in the water soon and test as well.
Also, if you want strong magnets, break open non functioning hard drives and use those magnets, they are very strong and light!
  #40   Spotlight this post!
Unread 04-05-2008, 13:55
AKA: Ledge
Tried looking, can't find it. Nice website though!
  #41   Spotlight this post!
Unread 04-05-2008, 14:14
MrForbes's Avatar
AKA: Jim
On the left is a list of stuff, go to "gears" then "racks" and you'll hopefully find something like this
https://sdp-si.com/eStore/Select.asp...SearchPattern=
but it's a frames web page, so you need to see all the frames at once, and I can't link to all of them at once!
  #42   Spotlight this post!
Unread 04-05-2008, 14:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Change the search to "keyword" and type "rack"
  #43   Spotlight this post!
Unread 04-05-2008, 19:28
AKA: Ledge
Awesome Thanks!
  #44   Spotlight this post!
Unread 11-05-2008, 20:07
MrForbes's Avatar
AKA: Jim
I finally put some night video on youtube
http://www.youtube.com/watch?v=TrQC1tjaLe0
Sorry it took so long!
  #45   Spotlight this post!
Unread 12-05-2008, 23:29
AKA: Ledge
Looks like you are getting lots of practice in! Great Job!
pic: 1726 modular robot TheOtherGuy Extra Discussion 16 08-02-2008 16:35
1726 Prototype Testing TheOtherGuy Robot Showcase 54 01-02-2008 00:12
pic: FRC 1726 Steering Prototype MrForbes Extra Discussion 15 12-01-2008 21:21
pic: 1726 NURC ROV s_forbes Extra Discussion 11 13-06-2007 23:54
pic: Rookie Team 1726 Final Robot yodameister Robot Showcase 10 24-02-2006 01:07
