Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 04-05-2008, 17:36
knine143 knine143 is offline
FRC #1047
knine143 is on a distinguished road
Open COM Serial Port
Hey all,
I have a Garmin Etrex H which streams serial data in rs232 format. It is simply ASCII characters. A terminal program on my computer receives them and displays them on my screen just fine. Also, my RC is able to send and receive data to and from my terminal program. Both the RC and the Garmin are set to 9600 baud, no parity, and one stop bit.
However, when I attach the Garmin directly into the RC, the RC does not receive any data. I think this is because the RC is waiting for something to start communication with it, and the Garmin is also waiting. How can I open port 1 on the RC and start communication with the Garmin? I'm using Kevin Watson's serial code.
Thanks alot!
Unread 04-05-2008, 17:46
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Open COM Serial Port
You need to do a level shift of RS232 voltages to TTL voltages. Are you sure you have Transmit on the GPS going to the Receive Pin?
When I hook the GPS to the Vex controller, I use the orange level shifter and a null modem to get the signals to swap.
Unread 04-05-2008, 18:06
FRC #1047
I'm plugging it in to the program port, which I believe is already rs232. It shouldn't need a level shifter.
Unread 04-05-2008, 18:18
FRC #1047
I set the baud rate of port 1 (the program port ) to 9600 using Kevin's code. And since it can talk to the terminal program on my computer at baud 9600, i know its working at that baud.
Unread 04-05-2008, 18:59
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Sounds like you might need a null modem
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 04-05-2008, 19:06
FRC #1047
Ya some of the things on that Wikipedia sound like it would fix the problem.
Why though would swapping the Tx and Rx lines make the Garmin send data to the RC all of a sudden?
Thanks
Unread 04-05-2008, 19:51
FRC #1047
The null modem worked! Thank a lot!
Unread 04-05-2008, 20:22
Thanks
The wiring was such that Tx was connected to Tx, and Rx to Rx. The adapter simply swapped it such that Tx->Rx, and Rx<-Tx. Voila!
Lovely little things to have around, especially when you make your own cable harnesses.
Unread 04-05-2008, 23:32
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Thus, if I'm not mistaken, the magic behind the Red Tether Cable (simply a null modem cable).
Unread 05-05-2008, 07:45
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Bingo
___________________
- Tennyson, Ulysses
No Serial Port G1279 Programming 5 10-01-2008 15:15
Which Serial Port? crossedheart Programming 4 08-02-2006 11:35
Serial port question ducttapehaxor Programming 7 30-09-2005 17:55
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
