Go to Post Finally I wish everyone here on ChiefDelphi good luck and more importantly a fun build season. - mechanicalbrain [more]
Unread 05-05-2008, 10:59
Mechanical's Avatar
Mechanical Mechanical is offline
AKA: Chris
FRC #2487 (Mechanical Animals)
Mechanical is a jewel in the roughMechanical is a jewel in the roughMechanical is a jewel in the roughMechanical is a jewel in the rough
Question PWM Cables
What is the Best place to find spools of PWM cable and crimps?:
[color="DarkGreen"][font="Book Antiqua"]Not bad for a rookie team huh? [/FONT
Unread 05-05-2008, 11:13
The Lucas's Avatar
CaMOElot, it is a silly place
Re: PWM Cables
My team orders form Hansen's Hobbies. There are several threads about this with other ordering options (if you want to search), but as far as I'm concerned, Hansen's is the only name you need to know.
EDIT: I don't like their deluxe wire, the fine strands make it too flexible and hard to insert the connector into the housing. I recommend the economy wire.
Robot Inspector
Unread 05-05-2008, 11:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: PWM Cables
We got a PWM crimper plus the pin and socket crimps and the 3 position shrouds from Mouser Electronics.
Part numbers:
538-63811-1000 Molex Tools UNIVERSAL CRIMP TOOL
538-11-03-0036 Molex Tools EXTRACTION TOOL
538-11-02-0022 Molex Tools INSERTION TOOL
538-16-02-0114 Molex SL Connectors TERMINAL 24-22 BULK
538-16-02-1114 Molex SL Connectors FEMALE HIGH FORCE
538-50-57-9003 Molex SL Connectors HSG 3P SINGLE ROW
As for PWM wire.... You don't actually have to use the flat 3-conductor cable that's typically used on the kit and IFI cables. Unless you're extremely worried about weight, I'd use some standard 22AWG 3-conductor shielded or unshielded cable. I think the flat stuff is a bit more annoying to work with, and more exposed to the tender mercies of the Mechanical crew.
Unread 05-05-2008, 12:05
Re: PWM Cables
Digikey is also a good source.
Unread 05-05-2008, 14:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: PWM Cables
Also, remember to use stranded wire, not solid. The stranded wire is much more flexible, and withstands repeated flexure much better than the solid stuff. It will probably crimp better as well.
I've actually used McMaster-Carr 7673K21 wire for heavy-duty aircraft servos (a few times stronger than the HS-322HDs we're allowed in FIRST), in an application where it might have to be re-fed many times through a blind conduit. It's probably too heavy for the intended use, but it's pretty much bulletproof. McMaster-Carr also sells some interesting silicone-insulated ribbon cables that might be useful: something like 9634T302 (24 AWG), for example.
Unread 05-05-2008, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
Re: PWM Cables
Try these
http://www.chiefdelphi.com/forums/sh...ad.php?t=46488
http://www.chiefdelphi.com/forums/sh...d.php?p=442408
The mouser link is good too, they are who I buy the pins, sockets and bodies from. Radio Shack has a good crimper, and wire is from eBay
Don
Unread 05-05-2008, 21:35
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: PWM Cables
Agreed... we have found them to be cheaper than some of the other, bigger places, as well.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Making PWM cables? HokieTutorunie Electrical 9 08-04-2007 12:29
custom PWM cables bruss6 Electrical 6 16-02-2007 08:33
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
