Go to Post Our job as mentors isn't to teach them how to make a robot...It's to teach them that there is value in technology and being among the people who create it. - Andy A. [more]
View Poll Results: Should we use our machines a lot?
yes, for everything 7 21.88%
yes, but only small parts 2 6.25%
yes, but only for bigger parts 0 0%
no, use it only when needed 7 21.88%
no, never use it 0 0%
It depends on the part (please elaborate) 16 50.00%
Voters: 32. You may not vote on this poll
Unread 05-05-2008, 21:07
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Machining Your Own Vs. COTS
We're getting a plethora of big new machines next year and have been having little mini debates about whether we should machine things like wheels, and other parts or just buy COTS versions. We're also debating about if should use our new CNC for the precision or use the good old measure twice cut once method on bigger parts, holes, and cuts.
Please post your all your opinions on how we should handle these machines, my current thoughts are that we are going to be using them way too much and use them for things much more suited for a normal saw or drill press.
Unread 05-05-2008, 21:18
dtengineering's Avatar
AKA: Jason Brett
Re: Machining Your Own Vs. COTS
Well, I was going to vote for "no, never use them... ship them up to us and let us play with them", but didn't see that option.
What I would suggest is that you use them for everything you possibly can in the off-season to learn their strengths and weaknesses and to get good with them so that you can produce parts reliably and quickly.
Then you can make intelligent decisions about how to use them during the build period. It isn't as simple as "small parts" or "large parts"... but rather which parts are most suitable for CNC machining, and what parts can you make with CNC that were not available to you in the past.
Get creative... you have now broken free of 90 degree corners and straight lines!
Jason
Unread 06-05-2008, 01:43
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Jason
I don't know, our robots have never had exact right angles- the only time I even tried was with a friend of mine, unfortunate freshmen that we were. The only piece on the '06 robot that was perfectly parallel to the floor, and the robot worked better without the piece. We always say our robot is built on 89 to 91 degrees, if that accurate. And competitions always gives our robot curves... (in the polycarb)
Anyway, if you can't justify using the CNC for machining an easily purchased part other than the "coolness" factor, buy the COTS. However, consider whether a machine-competent team member or a machine-competent member and a machine newbie has something to do and how soon you need the part. Machining for the team is an excellent way of sharpening (no pun intended) skills while involving as many members as possible. Also, CNC machines and mills are excellent ways of attracting attention for your team, so think about summer workshops for new team members. For some reason, people are always interested in the big and dangerous, i.e. robots. And remember your safety glasses!
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 06-05-2008, 01:55
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Don't get so wrapped up in the "I can make anything on the CNC machine!" mentality that you spend ten hours making a single wheel when you can buy a Colson wheel for $4.50 (and with minimal custom machining) and have it do the same job.
It's all about the cost to benefits ratio, or the return on investment. It it makes sense to machine it via CNC, do it. Otherwise, don't.
Engineering is not about designing everything as custom parts, or making it all "in-house". It's about finding the most effective and efficient solutions with regards to cost, time and resources.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-05-2008, 21:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The answer is it depends.
If you have something that needs to be extremely accurate, or you need to make a bunch of them, or it has angles and contours, then you'd want to use the CNC.
If you have a simple part you can make with a bandsaw and a power drill, you wouldn't want to use the CNC.
My formula for buying COTS vs making your own would be to decide:
Can we get the same functionality out of a COTS part as a custom?
How much more will it cost to go COTS?
How much longer (or shorter) will it take to get the COTS part?
Am I going to spend more than price premium of the COTS part to actually make it myself?
What else could I be making with my CNC, that isn't available as a COTS part?
If the answers to those questions favor COTS parts, then it's probably a worthwhile investment.
2001-2004: Team 100
2006-Present: Team 254
Unread 05-05-2008, 21:29
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
to add to Cory's comments -
use the off-season to learn the machines.
then, during build time -
if the part an easily be purchased, purchase it.
focus your design and fabrication time and attention and your machine tools on the parts that you cannot buy and need to be custom made for your robot.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 05-05-2008, 22:36
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
One thing that becomes obvious after a few years of this competition is that you can't make everything yourselves. If you can buy what you need, that's better than making it, unless you're under severe time constraints (which almost never happens to us, since we're literally within driving distance of McMaster-Carr).
Personally, I would reserve the new tools for the complex parts, and try to stay away from using them unless they're actually necessary.
Unread 05-05-2008, 23:00
Doesn't it also depend on the precision required for the product and cost/quality ratio?
Unread 05-05-2008, 23:44
Or, as in the case of sprockets (one example), you can get COTS and modify them using the machines, e.g, lightweight them.
Unread 06-05-2008, 00:58
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I would say to do a combination of the 2. If you can purchase something that works just a well as what you can make and is cost effective then by all means purchase it. That will save machining time for other more complex things that need to be machined.
As far as using mills to do large things, I somewhat favor it, especially for fabricating drivetrain plates, or things like that just because the accuracy is so much greater than could be achieved with just measuring and a drill press and band saw.
Mentor 2415
Make your own CNC whytheheckme Technical Discussion 8 25-07-2007 02:13
Make Your Own Whiteboard! buss General Forum 13 15-01-2007 17:58
Your Own Team Siggies Cujo General Forum 8 26-02-2005 16:01
FIRST Haikus... add your own! IsabelRinging Chit-Chat 53 16-01-2003 18:12
Making your own gearbox? ChaosMonkey Motors 15 25-05-2002 11:07
