| View Poll Results: Should we use our machines a lot? | |||
| yes, for everything |
7 | 21.88% |
| yes, but only small parts |
2 | 6.25% |
| yes, but only for bigger parts |
0 | 0% |
| no, use it only when needed |
7 | 21.88% |
| no, never use it |
0 | 0% |
| It depends on the part (please elaborate) |
16 | 50.00% |
| Voters: 32. You may not vote on this poll | |||
Re: Machining Your Own Vs. COTS
to add to Cory's comments -
use the off-season to learn the machines. then, during build time - if the part an easily be purchased, purchase it. focus your design and fabrication time and attention and your machine tools on the parts that you cannot buy and need to be custom made for your robot. |
One thing that becomes obvious after a few years of this competition is that you can't make everything yourselves. If you can buy what you need, that's better than making it, unless you're under severe time constraints (which almost never happens to us, since we're literally within driving distance of McMaster-Carr).
Personally, I would reserve the new tools for the complex parts, and try to stay away from using them unless they're actually necessary. |
Doesn't it also depend on the precision required for the product and cost/quality ratio?
Or, as in the case of sprockets (one example), you can get COTS and modify them using the machines, e.g, lightweight them.
I would say to do a combination of the 2. If you can purchase something that works just a well as what you can make and is cost effective then by all means purchase it. That will save machining time for other more complex things that need to be machined.
As far as using mills to do large things, I somewhat favor it, especially for fabricating drivetrain plates, or things like that just because the accuracy is so much greater than could be achieved with just measuring and a drill press and band saw. |
| Make your own CNC | whytheheckme | Technical Discussion | 8 | 25-07-2007 02:13 |
| Make Your Own Whiteboard! | buss | General Forum | 13 | 15-01-2007 17:58 |
| Your Own Team Siggies | Cujo | General Forum | 8 | 26-02-2005 16:01 |
| FIRST Haikus... add your own! | IsabelRinging | Chit-Chat | 53 | 16-01-2003 18:12 |
| Making your own gearbox? | ChaosMonkey | Motors | 15 | 25-05-2002 11:07 |
