Go to Post Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. - Andrew Schreiber [more]
View Poll Results: Should we use our machines a lot?
yes, for everything 7 21.88%
yes, but only small parts 2 6.25%
yes, but only for bigger parts 0 0%
no, use it only when needed 7 21.88%
no, never use it 0 0%
It depends on the part (please elaborate) 16 50.00%
Voters: 32. You may not vote on this poll
Unread 05-05-2008, 22:36
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Machining Your Own Vs. COTS
One thing that becomes obvious after a few years of this competition is that you can't make everything yourselves. If you can buy what you need, that's better than making it, unless you're under severe time constraints (which almost never happens to us, since we're literally within driving distance of McMaster-Carr).
Personally, I would reserve the new tools for the complex parts, and try to stay away from using them unless they're actually necessary.
Unread 05-05-2008, 23:00
Doesn't it also depend on the precision required for the product and cost/quality ratio?
Unread 05-05-2008, 23:44
Or, as in the case of sprockets (one example), you can get COTS and modify them using the machines, e.g, lightweight them.
Unread 06-05-2008, 00:58
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I would say to do a combination of the 2. If you can purchase something that works just a well as what you can make and is cost effective then by all means purchase it. That will save machining time for other more complex things that need to be machined.
As far as using mills to do large things, I somewhat favor it, especially for fabricating drivetrain plates, or things like that just because the accuracy is so much greater than could be achieved with just measuring and a drill press and band saw.
Mentor 2415
Make your own CNC whytheheckme Technical Discussion 8 25-07-2007 02:13
Make Your Own Whiteboard! buss General Forum 13 15-01-2007 17:58
Your Own Team Siggies Cujo General Forum 8 26-02-2005 16:01
FIRST Haikus... add your own! IsabelRinging Chit-Chat 53 16-01-2003 18:12
Making your own gearbox? ChaosMonkey Motors 15 25-05-2002 11:07
