Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 06-05-2008, 08:43
Gdeaver Gdeaver is offline
FRC #1640
Re: Victor logistics.
If you want to build a motor driver and are going to use 12 volt or more then there are some single chip solutions that can offer more ability. The victor everybody is familiar with is an open loop design. It provides no feed back or protections. If you going to use a micro controller to command the H-bridge then with a little more work you can have Current feed back, thermal protection and over current protection. With current feed back and knowing the motors current function then you can have sensorless speed control with fair accuracy. For low current motors look at the Freescale MC33887. For more current ability the ST Micro Electronics VNH2SP30 chip offers many features.
Infineon also offers the BTS 7960 and BTS7930. These are half bridge chips.
Pololu.com offers the first 2 chips on carriers and would simplify working with them. They are surface mount and not for bread boarding. Robotpower.com offers the simple H with the BTS7960. The nice thing about the VNH2SP30 is that it only needs the fixed frequency - variable duty cycle PWM on 1 pin. The other chips need 2 PWM outputs from the microcontroler. The next step to this is to control the speed controller over a serial buss. Note that the Lego NXT offers I2c and RS485 for this purpose. May be First and IFI will add some intelligence to the next generation speed controllers.
Victor Problems Justin M. Electrical 8 13-02-2008 17:41
Victor 883's? hunter7193 Electrical 0 10-02-2008 17:13
Victor Lights robobrain0101 Technical Discussion 9 13-02-2007 15:18
victor mosfets sciguy125 Electrical 13 19-07-2006 09:15
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
