Go to Post "If a student CAN do it, a student SHOULD do it." - Mr. Lim [more]
Unread 06-05-2008, 04:40
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: Victor logistics.
Well said!
Any recommended mosfet & drivers?
| jamesyong.net |
FVC2007, FTC2008
Unread 06-05-2008, 08:43
Gdeaver Gdeaver is offline
FRC #1640
If you want to build a motor driver and are going to use 12 volt or more then there are some single chip solutions that can offer more ability. The victor everybody is familiar with is an open loop design. It provides no feed back or protections. If you going to use a micro controller to command the H-bridge then with a little more work you can have Current feed back, thermal protection and over current protection. With current feed back and knowing the motors current function then you can have sensorless speed control with fair accuracy. For low current motors look at the Freescale MC33887. For more current ability the ST Micro Electronics VNH2SP30 chip offers many features.
Infineon also offers the BTS 7960 and BTS7930. These are half bridge chips.
Pololu.com offers the first 2 chips on carriers and would simplify working with them. They are surface mount and not for bread boarding. Robotpower.com offers the simple H with the BTS7960. The nice thing about the VNH2SP30 is that it only needs the fixed frequency - variable duty cycle PWM on 1 pin. The other chips need 2 PWM outputs from the microcontroler. The next step to this is to control the speed controller over a serial buss. Note that the Lego NXT offers I2c and RS485 for this purpose. May be First and IFI will add some intelligence to the next generation speed controllers.
Unread 07-05-2008, 00:30
deus ex programmeur
AKA: James Yong
FTC #0747
VNH2SP30 - 30A, surface mount only
BTS7960B - 60A half bridge
Personally would prefer the BTS7960 as two of them make a full bridge and I can directly drive them using the 2-phase PWM output of the PIC or ATmel controller, and you can also add a heatsink to it. Now my only issue is having a bunch of them shipped to my location...
| jamesyong.net |
FVC2007, FTC2008
Unread 07-05-2008, 17:06
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
The chips referred use duty cycle pwm up to 20Khz as input, this would not work with the RC pwm used on the microcontroller...... At least, I think thats right.
As for mosfet types:
http://www.irf.com/product-info/data...a/irf3704z.pdf
The IRF3704Z is a pretty powerful fet. And Current output to power dissapation ratio is fairly good.
Go here if you want to pick your own mosfet specs.
https://ec.irf.com/v6/en/US/adirect/...N=0+4294841672
You can read this guide for pairing up FETS with drivers. Provided by Microchip.com
http://ww1.microchip.com/downloads/e...tes/00799b.pdf
Victor Problems Justin M. Electrical 8 13-02-2008 17:41
Victor 883's? hunter7193 Electrical 0 10-02-2008 17:13
Victor Lights robobrain0101 Technical Discussion 9 13-02-2007 15:18
victor mosfets sciguy125 Electrical 13 19-07-2006 09:15
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
