Go to Post You don't have enough money, you're under-staffed, you're not quite sure what the customer wants, requirements change, and they want it yesterday. - Kimmeh [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 06-05-2008, 14:55
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: .ipt to dxf? to CNC machines?
Originally Posted by Generalx5 View Post
Thanks Arthur!
One more question, when I save as to a dxf file in inventor from an idw file, what actually is happening to the new file created? When I found it, it had been zipped, and when I opened it, 2 or 1 text file appears, inside is a mass amount of code....not programming code, looked like random segments. When someone outside opens it properly with a dxf opener, are they able to see the model dimensions? will it be in 2D or 3D...If I didnt dimension the idw file to begin with, would the dxf file be dimensionless?
I don't know how Inventor exports DXF files, as I haven't used it for exporting to a CAM program. But DXF files can be 2D or 3D, though I usually stick to only 2D DXF models.
Usually, as long as the DXF file is exported at a 1:1 size ratio, the dimensions can be found from the model itself.
Art Dutra IV
世上无难事,只怕有心人.
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
Inventor (*.ipt) -> Dxf patTeam241 Inventor 5 16-02-2004 23:09
