Go to Post A good measure of Integrity is what you do when nobody's watching. - DonRotolo [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 06-05-2008, 00:00
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
.ipt to dxf? to CNC machines?
How do I get an ipt file to work with a CNC machine? I have a few aluminum parts that I've designed for use on the chassy, how do I export the ipt file so that the CNC mechanic or computer can read its dimensions?
I have more than a dozen parts, so dimensioning them would take a while, the CNC mechanic person would also have to design it back so he can run it on the CNC. Is there a way to convert the ipt file to a standardized format so that I dont have to dimension them, whoever opens the file, all dimensions will be available to them Via computer.
Is there even such a thing?
Unread 06-05-2008, 01:44
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: .ipt to dxf? to CNC machines?
I use SolidWorks, but here is the general process on how parts go from a CAD model to a finished part via CNC. (It's good to keep the entire process in mind, even if you are just designing the parts).
  1. The first thing I do is make sure the part is actually manufacturable on the machines that I will be running it on. On milling machines, there cannot be any square inside corners (though you can use a small drill at the corner to achieve a square), and make sure any part radiuses are as large as they can. There's no sense in using a 1/8" end mill to make all those 0.0625" radius' corners if you can use a 1/2" end mill and functionally the part will be the same.
    Also as a subset of this, if the part is "deep", make sure you only use large radaii down there. They don't make things like a 1/4" end mill that has three inches of vertical cuttable edge. Also, if you want to do engraving on the surface, I've found that a number four center drill at a depth of five thousandths work well.
    Another thing to think about is how the part you are making can be held down while it is being milled. Rectangular parts are usually easy (they can just be clamped in a vise), though if you want holes or pockets near the edge (which might hit the parallels), you will need to figure about another way to fixture the part. Soft jaws (custom aluminum jaws made to hold that specific part) are one option, using bolts and mounting the part on a fixturing plate is another.
    Another critical thing to keep in mind is which dimensions are critical, and their expected tolerances. You should mark all part dimensions on a separate file from the main part, and show all part tolerances as well. Make sure all tolerances are set as low as possible; if certain dimensions or features are not critical, don't specify that they need to be within a tolerance of 0.0001" if a tolerance of 0.01" is just fine. Leaving the dimensions lower can make the part easier to be machined, as well as result in faster production time.
    Before the part can be made, the above points are crucial. Just because the part looks good in Inventor or SolidWorks does not mean that it can be manufactured.
  2. The next thing to do depends on what CAM program that use. For my parts, I always export a DXF of the part from SolidWorks and import that into the CAM program (FeatureCAM) that I use. There are a lot of different CAM programs, such as MasterCAM, GibbsCAM, Espirt, etc.) so the process may be different in each.
    But once I have the DXF (make sure it is exported at 1:1 (full-size) ratio), I import it into FeatureCAM. From here, I have to set the material size and composition, where the part origin is, how the X/Y/Z axis' are orientated, and where the part is in relation to the material. Then from here, I have to make each machine operation, such as pockets, grooves, holes, etc. I also select the tool, the feeds and speeds, the operation (climb or conventional), if I want a rough pass with a second finishing pass, how much material I want to take off in each pass, etc.
    Granted, FeatureCAM does help along the way and has a lot of preset options, but it is impossible just to import a .sldpart or .ipt file and expect it to do everything to make a .nc file for me.
  3. The next step is I simulate the CNC operation in FeatureCAM. This usually tells me if something wrong happens, like if I set a feature offset wrong and the cutter rapids into the part.
  4. Once this looks good, then I can generate the .nc file. The .nc file is what actually runs on the CNC machine. When you generate the .nc file, you also need to make sure you select the right post-processor for the machine you are using. I had a friend give me his customized post-processor for working with Haas CNC machines, as most CAM software only comes with generic post-processors.
If the CNC work is being down by an outside person/company, consult with them, and ask what software and file formats they use. Generally, I've found STEP (.stp) files to be pretty universal for 3D models, and DXF files to be pretty universal for 2D models.
Also, in addition to the part models, it is always useful to submit a dimensioned drawing of the part, showing all the critical dimensions and their tolerances, as well as the number of parts needed, the material required, and any other part features which are important to keep in mind while manufacturing the part.
I'd suggest that if you don't have any experience in this field, ask for a tour of a CNC machine shop, and ask lots of questions along the way about the process. You'll learn a lot, and it'll most likely make your part designs even better.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-05-2008, 06:05
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Thanks Arthur!
One more question, when I save as to a dxf file in inventor from an idw file, what actually is happening to the new file created? When I found it, it had been zipped, and when I opened it, 2 or 1 text file appears, inside is a mass amount of code....not programming code, looked like random segments. When someone outside opens it properly with a dxf opener, are they able to see the model dimensions? will it be in 2D or 3D...If I didnt dimension the idw file to begin with, would the dxf file be dimensionless?
Unread 06-05-2008, 14:55
artdutra04's Avatar
Originally Posted by Generalx5 View Post
Thanks Arthur!
I don't know how Inventor exports DXF files, as I haven't used it for exporting to a CAM program. But DXF files can be 2D or 3D, though I usually stick to only 2D DXF models.
Usually, as long as the DXF file is exported at a 1:1 size ratio, the dimensions can be found from the model itself.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-05-2008, 16:17
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Thanks Arthur!
I have one question
What version of Inventor are you using I know that when i export files from inventor 2008 for use in CAM programs it creates a file that is just a .dxf extension file also when you export the 2d drawing you want to make sure that you delete the the border and the box with the part name and that sort of stuff the person making the G code for the mill will thank you also i would make sure that the drawing has not been dimensions because it makes the person running the CAM program delete a lot of stuff and as long as the part was in a 1:1 ratio when you put it on the idw you should be fine
Unread 06-05-2008, 18:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Thanks Arthur!
It sounds like Inventor is exporting an ASCII DXF file (as opposed to binary). You ought to be able to find a free viewer online and check to make sure it's exporting correctly and that the dimensions are correct.
--Madison--
...down at the Ozdust!
Unread 06-05-2008, 23:41
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Thanks, I will find something that can view the dxf file right after this post.
I don't understand about the idw to dxf transition. Is the Dxf file a 3D model? how does it "rebuild" itself form a 2D file such as the idw format. Thanks for mentioning about deleting the boarders and dimensioning it, would it be okay if I had several views of the model? top view, front view, iso metric, and cutaway view.
Thanks for the tips!
Oh right! I am using Autodesk Inventor 10...on a vista, with a really nice virtual PC tool =D Thank god!
Unread 07-05-2008, 03:13
artdutra04's Avatar
All you need to recreate any 3D part from 2D drawings are dimensioned top, front, and side views - or in other words, one sketch of the part in each of the XY, YZ, and XZ planes. Depending on part complexity, additional drawings or cutaway views can also be helpful. Adding an isometric view can also help visualize the part for the person reading the drawings.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-05-2008, 15:53
Jeff 801's Avatar
Another Question what CAM program are you using like are you using MasterCMA, Gibbs CAM or what came with the CNC
Unread 07-05-2008, 16:50
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Sorry for not saying, the actual answer I still don't know, Im looking for CNC shops that are open to public/commercial contracts. with no minimum order quantities. So....I hope that answers your question, Im guessing it would be something common. Mastercam or Gibbs. Are there any significant differences I should take note of?
Unread 07-05-2008, 18:27
Jeff 801's Avatar
I would look here
http://www.chiefdelphi.com/forums/sh...ad.php?t=59985
and
http://www.chiefdelphi.com/forums/sh...ad.php?t=28982
Unread 08-05-2008, 18:57
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Im courious to how much one would have to spend...on average for a custom part to be made on a CNC.
What would the cost be for something like a custom motor mount bracket. Complexity? Chamfered edges, not so complex. I will need 6 of these. Know the cost?
Unread 08-05-2008, 19:50
artdutra04's Avatar
It really depends on the part. Part cost depends on the material used, the number of setups required to machine the part, and the labor to make do the CAM work and run the part on the machines.
If you post some photos of the parts in question, it would be easier for us to make a better assesment of the part.
Art Dutra IV
世上无难事,只怕有心人.
Unread 09-05-2008, 13:12
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Heres a look at the right side bracket. its not completely finished...75% done.
See attached pictures.
Thats a 12" x 5" base with a motor mount on the circular portion of it, and a support bracket on the other end.
ID:	6636  Click image for larger version
Unread 09-05-2008, 13:32
Madison's Avatar
FRC #0488 (Xbot)
You'll want to make that from two or three pieces.
--Madison--
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
Inventor (*.ipt) -> Dxf patTeam241 Inventor 5 16-02-2004 23:09
