Go to Post Swerve Drive (n.) - a set of mechanisms to ensure the robot will sit dead on the field for half of that robot's first event - Kevin Leonard [more]
Unread 09-05-2008, 20:44
Re: Labview and Sensors
Originally Posted by Jon236 View Post
Greg,
can we assume that the sensor VIs from the NXT toolkit will look like the VI's we will be using?
My smartaleck answer: They will both be small square icons with wires coming from them.
Better answer: The NXT toolkit icons are similar, but simpler. Their implementation is built on top of LEGO I/O -- either analog, or I2C. Learning how to do robotics using the NXT toolkit will be a good way to prep for the upcoming FRC libraries.
Greg McKaskle
CMUCam, Easy C, and Labview JJMax7 Programming 28 07-02-2007 22:20
Labview and the IFI hardware ajlapp Control System 3 21-09-2006 16:09
Labview dashboard and multiple variables Joe Ross LabView and Data Acquisition 2 15-03-2006 21:55
Camera and Labview phrontist LabView and Data Acquisition 1 28-01-2006 21:07
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
