Go to Post Mob JVN for autographs - Jay Trzaskos [more]
  #61   Spotlight this post!
Unread 01-04-2008, 13:46
Re: witricity legality?
I'd like to apologize for my rather... short post about feasibility. As an RF Engineer Apprentice, I'd like to let you know that this sort of stuff is actually a lot of fun.
This specific experiment might not be feasible, but there is a lot of other cool stuff to do in this vein. RFID is a very very similar principle. Take a look!
  #62   Spotlight this post!
Unread 01-04-2008, 15:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, lots of info in this thread and a neat idea.
Keep in mind that the power curves of most FRC motors extend upwards to at least ~150watts. If power out = (efficiency) * power in, where efficiency is less than 100%, then it takes more than 150watts of power to make the motors run. Add in the efficiency of the witricity system and you're faced with coming up with a way to power 5-6 60 watt lightbulbs at once instead of just one.
I'm not going to tell you it's impossible, because actually I think it is. Is it practical in FRC with your drive train, compressor, and other possible motors running? That's what experimentation is for, so I don't know. It's hard to say if the battery output could keep up for a full 2:15. Even with the '07 or '08 rules, the GDC may have accomodations in the rules to make it legal in '09 (but don't get your hopes up).
GitHub
  #63   Spotlight this post!
Unread 08-05-2008, 00:38
roboxking roboxking is offline
AKA: Chris
FRC #2584 (Reseda Regent Robotics)
roboxking is an unknown quantity at this point
Originally Posted by XXShadowXX View Post
witricity which using resonating magnetic coils was proved possible my mit last year by using it to light a 60watt light bulb 2m away. With stuff blocking directing line of sight
also Tessala (can't spell) using witricity to transmit massive voltages over great distances, one example is that in a eletrical field you can light flourencent lights with out plugging them in.
the laws of physics allow this to work, but im not sure if the metal frame would interfere. Also other eletronics can work in a witricity feild if they don't opperate on the same frequency they will not conduct the current. Which is why you make sure that the cycles of the field is very high (10megahertz or higher).
MIT tested this device, there was 40% power loss in transmission. If we weren't going for speed this could be viable i think. You know for a engineering award.
You are correct, WiTricity is physically possible. however, probably incredibly destructive. Look at the nature of electricity and plasma. Plasmas (this includes fire and electricity) Plasmas in their nature are designed to destroy everything they get into contact with. The amount of energy require to transfer electrical potential is incredibly powerful, and can destroy not only human cells, but electrical circuits. everything in the path of these waves will be instantly destroyed. You can essentially kiss all of your electronic components good bye. And no, these cheap little electronic devices aren't made to withstand such a destructive force. Hope this clears up any notion to use such an experimental procedure.
  #64   Spotlight this post!
Unread 08-05-2008, 08:52
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I need to correct a little here:
1> Witricity is RF, which is the transfer of electricity (electrons) through a medium in a specific frequency band. It is not conversion of that electricity (electrons) into plasma (charged ions).
2> Plasma is not inherently destructive. There are many factors that go into what plasma does. Energy levels, frequency, material being affected, etc. I use plasma all the time in surface treating applications where I work.
3> RF (like Witricity) is also not inherently distructive. You have RF going through you everyday. Cell phones, WiFi, Radio (including the RC radio), RADAR all use RF. There's also natural RF generators (our sun is a good example).
Now I'm not saying that Witricity would not be destructive. Properly implemented and controlled it could be very useful and nondestructive. The key is an understanding of the effects that the fields will have on the local enviroment and nearby objects. And "those cheap little electronic devices" ... you'd be surprised how much RF they can handle (at specific frequencies).
___________________
- Tennyson, Ulysses
  #65   Spotlight this post!
Unread 08-05-2008, 10:39
Daniel,
One small correction, we are talking about electromagnetic energy in a certain frequency band.
  #66   Spotlight this post!
Unread 08-05-2008, 11:25
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel,
You are correct.
I don't generally differentiate between electromagnetic energy and electrcity because any movement of electricity within a medium creates a magnetic field (so for me it's an assumed thing).
Again, you are correct.
___________________
- Tennyson, Ulysses
  #67   Spotlight this post!
Unread 10-05-2008, 00:37
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
I havnt looked into this one bit, but does any one know where the power loss comes from?
After a quick wiki search...
It seems as if this technology is similar to transformers. either steup up or step down, so if the coils were identical, then theres no ups or downs but a direct transfer of energy via electromagnetic field. So...this makes me think that the 40% efficiency @ 7feet away conducted by MIT could have been more efficient if the two coils were close to one another....similar to a transformer. Is the high frequency necessary? I can feel the 60Hz "buzz" from my desk lamp if I put a metal object close to the base of the lamp. It doesnt seem to be affecting anything.....I will try a simple coil test right after I publish my post, Ill repost with the results form my Mastercraft Multimeter.
BRB!
  #68   Spotlight this post!
Unread 10-05-2008, 00:55
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Okay, so I see why they dropped the Witricity. As far as I can see, I didnt get any voltage, but I did get some current, 130mA was the average. As soon as I moved about 2cm awway I was down to only 20ma....Not a very good power supply... thats the end of that..
  #69   Spotlight this post!
Unread 10-05-2008, 07:58
BRB!
June,
There are a variety of places where the power is lost. Turning RF into an effective field is tough enough but then you add to that the power that is lost by not coupling all of that field to the receiving coil. The inefficient coupling between the coils due to a lack of focus of the field and the varying load on the receiving coil all add up as well. Certainly placing the coils closer together would help. The RF is used to make the coils small and light enough to be a practical demo. Lower frequencies would work but the coils become significantly larger for the same efficiency.
NJ Regional: IR Legality LH Machinist Control System 17 29-02-2008 06:27
Legality question SonicKidGJ VEX 6 13-01-2008 14:00
Legality question Tottanka Rules/Strategy 5 14-02-2007 14:32
legality question rbayer General Forum 8 15-09-2002 00:25
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
