Go to Post Please review the rules for posting. - meaubry [more]
Unread 11-05-2008, 16:24
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
Smile Programming Voltages in Easy-C
hello fellow team
we were having trouble w/ speeds and stuff w/ our robot
i found out that you can set voltages to motors to make the motor go faster
is this possible?
and if it is, how can i do this in Easy-C?
im not much of a programmer and i am learning w/ Easy-C
if anyone can help i would greatly appreciate it
thanks
-team 270
Unread 11-05-2008, 18:16
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Programming Voltages in Easy-C
I haven't used EasyC, but I know that it is very similar to WPILib, which I have used extensively.
Anybody, correct me if I'm wrong, but you use the SetPWM() function. You pass two values. The first value is the PWM port on the robot you want to output to, and the second value is the speed from 0 to 255. 0 is full reverse, 127 is neutral, and 255 is full forward.
Unread 11-05-2008, 19:52
Deer Park Driver
Team Role: Driver
cool, ill try that
thank you
Unread 15-05-2008, 17:23
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
This should be in the EasyC forum
You might find it easier to use the pre-written drive functions under the RC Control tab.
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Easy C programming Mentor08 Programming 7 27-02-2008 22:09
Programming Camera in Easy C Chief Samwize Programming 3 19-05-2007 20:37
Easy C Relay Programming Team_486 Programming 1 26-03-2007 15:01
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Easy-C Programming CD Jeff K. Programming 2 09-01-2006 02:20
