Go to Post Good tooling doesn't cost money, it makes money (and prevents doctor visits). - travis [more]
Unread 16-05-2008, 08:05
Re: pic: Looking for Info/Parts
As you know already, the two on the left are Bosch drill motors, 117 amps at stall. They don't like to be run at low speed with high load which got many teams into trouble with over temp. The motor on the right looks like a FP from about that time but is too small. However, the transmission looks like the guts to an electric screwdriver, so it is possible someone dissassembled the screwdriver and left it in your storage.
I have the motor sheet for the Bosch drills if you would like. Just PM me.
Unread 16-05-2008, 08:52
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
The motor on the right is the Bosch 3/8" cordless drill motor and transmission from 2001-2002.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 16-05-2008, 09:18
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
keep the motor on the right, throw the two on the left away
http://banebots.com/pc/MOTOR-BRUSH/M4-R0062-12
good luck
Unread 16-05-2008, 10:38
HUNT397's Avatar
HUNT397 HUNT397 is offline
AKA: Chris Hunt
FRC #0397 (Knight Riders)
HUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to behold
As people above have said the two on the left are the part DC980KA drill motors they did have a tendency to overheat and the leads on the back of the motor would heat up and unsoder themselves. If you were not carefull the brushes on the motor are exposed and extremly fragile.
THe lower motor is a 2000 - 2002 transmission 3/8 dewalt it has been retrofitted to stop the clutch plates from slipping and it also has Dr. Joe Johnson's Shaft in it.
Here are the links on how to retrofit a new one as well as the specs on them both.
http://www.chiefdelphi.com/media/papers/1558
http://www.chiefdelphi.com/media/papers/1336
http://www.chiefdelphi.com/media/papers/1313
MY 2cents run away!! the cim's are more powerfull and more reliable. if they are to heavy consider a NBD transmission with the fisher price motor.
http://www.chiefdelphi.com/media/papers/1592
Good Luck
Unread 16-05-2008, 11:05
Andy,
You are right, that is the drill motor from the smaller drill. I found the specs in the 2000 robot manual if you need them. Stall at 114 amps, similar problem with the need to keep speed up to cool the motor. The locking/anti-back drive pawls in the transmission produce serious problems for the housing if not removed.
Unread 16-05-2008, 16:53
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
I just took one off an old robot. Motor, gears and braket. If you were not so far away I would trade with you. All I have is the dimesions document http://www.team1322.org/documents.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 16-05-2008, 18:29
AdamHeard's Avatar
Lead Mentor
Hmmm.... for a 30 lb with low funds is somewhat of a dillemna.
Poor quality parts will break, and you will be frustrated and wish you had just done it right in the first place.
I've never built a 30, but I think two small CIMs would be a decent power source (although, compared to more expensive motors they have a poor power to weight ratio).
Unread 17-05-2008, 10:06
run the trap!!!
Team Role: Human Player
Its not that I have low funds. Its that I don't want to spend a lot of funds. I'd hate to buy some of the whyachi products and have my bot get trashed - thereby wasting my money.
If I remain conservative, and my robot is destroyed, then I won't be losing very much - capisci?
CIMs seem like they might be a reasonable alternative. If I use the NBDs approach I might be able to keep the weight down.
Thanks everyone!
-Philip J. Fry
Unread 20-05-2008, 01:17
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
go with banebots, you wont be disappointed. When Greg Needel and I designed his 30, we used 4 on it for the drive, and man it was powerful!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Looking for current Linux Info sparrowkc Programming 4 06-01-2008 20:34
Duel Info - Robot Parts for Ghana Collection Mr MOE Off-Season Events 0 24-09-2007 07:31
Looking for White papers and other useful info Japper General Forum 6 12-04-2007 11:43
looking for a bunch of teams for scouting info. kjohnson22002 Scouting 17 15-02-2004 17:51
Looking for Teams Info Ellery General Forum 0 01-02-2003 15:41
