Go to Post I still have 3 good ligaments left and 2 events, so I should be fine :rolleyes: - esquared [more]
Unread 18-05-2008, 01:10
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: 4 inch wheels
Thanks for the help, any other wheels?
R.C.
MadTown Robotics Team 1323
Unread 18-05-2008, 01:49
CraigHickman
Posts: n/a
Re: 4 inch wheels
Make em. Much more satisfying, educational, and expensive. But in the long run, I've found my custom wheels to be better tools to show off to potential employers, friends, and other random people.
Unread 18-05-2008, 06:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: 4 inch wheels
http://andymark.biz/am-0014.html
Unread 18-05-2008, 10:53
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: 4 inch wheels
Banebots just came out with some new wheels, apparently. http://banebots.com/c/WHB
$14 will get you a 4" wheel with whatever durometer you want (30, 40, 50) and hub to mount it on a typical keyed shaft. They also have a wide hub so you can double up two of the wheels. These look really neat, has anyone played with them yet?
EDIT: you can also just get a keyed wheel for $5! I really want to try them out.
Unread 18-05-2008, 10:56
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: 4 inch wheels
Our team has had great sucess using the NPC Robotics wheels. They are simalar to colsons, however come ready with a .5" bore w/ 1/8" keyway. We personally use the 6" variety, but (correct me if I'm wrong) team 148 used the 4" wheels this year on their swerve modules.
You can get them either at:
NPC Robotics
Robot Marketplace
Both sites have them for $19 a piece, which from what I have seen, is nice a cheap!
Good Luck.
-Chuck
Unread 18-05-2008, 16:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: 4 inch wheels
Those banebots wheels look like an amazing deal if they are decent quality. I am going to try to get some this summer to use on a prototype drivetrain. If they end up working well they will be a much better deal than even the colson variety.
As a side note we used the colson wheels from robotmarketplace that come keyed and they were flawless however for $7 for the banebots wheel it is a much better deal.
Mentor 2415
Unread 18-05-2008, 17:10
Gone Fishin'
Re: 4 inch wheels
Just remember, you will see a performance difference between the banebot wheel and the NPC wheel. Banebot's wheels come with softer rubber than the NPC wheels.
Depending one which wheels from BB you get, you will have different amounts of grip and wear. The 30A will be "grippyist", but wear the fastest. The 50A will be the one that has the lowest grip (of the BB wheels) but wear slower.
The NPC wheels are use a 70A durometer rubber. So ALL of the BaneBots wheels will have more grip, but wear faster as well.
This could also lead to eventual wheel changes on the BaneBot wheels if they wear too quickly for your liking, which could end up making them more costly than the NPC in the end.
-Chuck
Unread 18-05-2008, 17:33
AKA: Sean
Re: 4 inch wheels
That is very true about the hardness of the wheels. I would have preferred for the colson wheels to be a bit grippier so perhaps the banebot wheels at 50A will be just right. Also you could replace each wheel 3 times for the price of one npc wheel. Just a thought.
Mentor 2415
Unread 28-05-2008, 11:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 4 inch wheels
In regards to the 1/8" keyed shafts:
From Banebots Website:
NOTE: The broached polypropylene core should be durable enough for most applications; however, it may not be suitable for some strenuous applications. It is recommended to use a separate hub solution for strenuous applications.
This applies to the 6WD cantilevered "west coast" drive train setup. Until we know how durable these wheels are in a competition environment, it may pay to simply go with the high-traction soft rubber and plan to change the wheels every so often anyways. If a hex mount is chosen, it may also be more beneficial to use the 1/2" Hex shaft over the 3/8" hex shaft for the same reasons.
GitHub
Unread 12-06-2008, 17:58
R.C.'s Avatar
Re: 4 inch wheels
Does anyone have a link to a solidworks or inventor 4 inch double set omni wheel? Thanks in Advance.
R.C.
where to but 6 inch omni wheels jpyro Technical Discussion 3 12-01-2007 23:47
3 inch Mechanums CraigHickman Inventor 1 21-09-2006 19:18
Skyway 8-Inch Wheels: What A Drag Rick TYler Technical Discussion 9 31-01-2006 17:51
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
We NEED 8-inch wheels and programming help archiver 2001 7 24-06-2002 00:29
