Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 20-05-2008, 08:48
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: pic: Dual FisherPrice Gearbox
Originally Posted by Cory View Post
I think it'd be best to have the water jet cut it like 0.010 under and then ream the hole.
Whenever we get waterjetted parts the holes are usually clearance holes or tap drill holes and their diameter is not critical. Our guy cuts them slightly undersize then we open them up with the correct size drill.
I know Pink just cuts them slightly undersized and then anything that needs a bearing in it gets opened up with a reamer in a hand drill. I'd never have guessed you could get away with using a hand drill, but it sure works for them.
We also have the water jet cut them slightly undersized and ream them out. I can remember one instance where I failed to do so on a part and we ended up having to put a nut on the other end due to the hole being to big to tap with the bolt that we wanted to place in there.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 20-05-2008, 18:27
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Originally Posted by Aren_Hill View Post
any particular reason you couldn't just run a NBD setup in 1st gear? that'll get you a 47:1 reduction and would be faster and easier to make.
The only difference being orientation as the NBD setup would be longer and skinnier.
edit: nevermind just read the title this is for two... whoops, but you could just run two setups or 2fp's into one dewalt
http://www.chiefdelphi.com/media/photos/20145
http://www.chiefdelphi.com/media/photos/19245
That is a good idea. It would be much cheaper and lighter.
thanks, Vivek
"we don't build robots, we build people"
Unread 20-05-2008, 18:33
AdamHeard's Avatar
Lead Mentor
thanks, Vivek
Made me realize a completely COTS solution to getting ~ 48:1 from two FPs.
Two FPs into AndyMark planetaries into a toughbox yields a 46.8~1 reduction.
I know it's not the lightest, but It requires no machining or work besides assembly (and the FP pinion).
Unread 20-05-2008, 18:48
vivek16's Avatar
AKA: vivek
Adam,
I thought about that a while ago and ruled it out because it was too heavy. We are pretty concerned about weight.
How much does a prealtered dewalt gearbox assembly weigh?
If it is less than 2 pounds, it just may be worth it.
thanks, Vivek
Unread 05-08-2008, 13:34
vivek16's Avatar
AKA: vivek
Well, I altered the gearbox and added Idler sprocket mounts.
Here are a few pictures:
http://i200.photobucket.com/albums/a...INALRENDER.jpg
http://i200.photobucket.com/albums/a...i/DSCN7920.jpg
http://i200.photobucket.com/albums/a...i/DSCN7921.jpg
The first ones a render, the second two are of its construction so far.
thanks, vivek
EDIT: disregeard the messy desk behind the partially completed gearbox.
Unread 05-08-2008, 18:43
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
Messy, you don't even know messy.
Unread 05-08-2008, 23:37
vivek16's Avatar
AKA: vivek
haha, tell that to our mentors. We want an aluminum magnet purely for the purpose of picking up filings off the carpet.
I agree, that's the cleanest my desk's been in weeks.
I'll finish the gearbox on thursday hopefully. I couldn't get the gears off the fps so I'm going to go over to the auto body shop next to our workshop and ask to use their nut splitter. Maybe having broken fp gears will intimidate the next fp gears we try to get off to come off easier.
-Vivek
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
Gearbox/ Dual Motor Setup matt111 Technical Discussion 8 02-12-2003 09:43
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
