Go to Post I would contend that you cannot have a consistently good robot without equally good teambuilding. - jonathan lall [more]
Unread 20-05-2008, 23:56
erikab erikab is offline
FRC #1717 (D'Penguineers)
erikab is an unknown quantity at this point
pic: Team 1717's PenguinBot 2008
Unread 20-05-2008, 23:58
Re: pic: Team 1717's PenguinBot 2008
That thing competes like crazy. If you haven't seen 1717 in action, watch them on TBA.
2 regional wins and finalists against 1114, 217, 148 with the Poofs at their side. They were on fire this year.
Unread 20-05-2008, 23:59
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
This was one of the most robust looking robots that i saw this year. i thought it was the most professional looking bot at nationals.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 21-05-2008, 00:35
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Could anyone explain how they got that fast of a forklift built?
R.C.
MadTown Robotics Team 1323
Unread 21-05-2008, 01:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm glad 1717 is getting some attention this year, as this isn't the first time they've made an outstanding bot. If anything, their bot last year was even better (one of the best ramp bots of the year, and it could score a couple tubes), pity it didn't attend the Championship.
Unread 21-05-2008, 02:08
Amir's Avatar
Amir Amir is offline
FRC #1717 (dpengineering)
Amir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to behold
We used two fisher price motors inserted into banebots 64:1 transmissions. This decision was reached by performing some simple tests coupled with a motor curve analysis.
We built a simple winch set-up that used the fisherprice motors with the KOP fisherprice gearboxes. We evaluated the motor performance under load lifting different amounts of weight. We measured the current under load and compared this with the motor power curves. We then decided on a "safe zone" in which we felt comfortable operating our motors. This was between max efficiency and max power.
We then used a basic physics analysis, W=FD and P=W/t, using the predicted load of the ball and lift combined. Using this information and the data collected from our tests, we were able to determine the most effective transmission and winch diameter combination.
We actually played it safe with 64:1. We could have used 48:1 which would have made it lift even faster and still been within the limits of our "safe zone." We decided, however, to be conservative and stick with 64:1.
We ran this forklift up and down hundreds of times and played matches all the way through finals at two regionals and the championship and never had a motor problem. We bought 10 spares just in case and never had to replace a motor. The fisher price motors are really quite amazing if they are used under non-stall conditions and at the sweet spot on their power curve. Finally, our lift had a built-in ratchet that did not allow the motors to back drive.
Hope this is somewhat clear and informative
Amir
Unread 21-05-2008, 17:28
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I'd have to say that this is one of very few robots I've ever seen who built to a theme (robot resembles a penguin) and didn't compromise effectiveness or success. Btw, do you have a part number for the BB transmissions you used on the FPs?
-Dustin Benedict
Unread 21-05-2008, 17:31
AdamHeard's Avatar
Lead Mentor
I'm 99% sure they used the 42mm series of the 64:1 (We know it's 64:1 from what Amir said).
Unread 21-05-2008, 17:44
thefro526's Avatar
Mentor for Hire.
How much is required to get these to work? Is it just changing the gear on the motor or a lot more work?
-Dustin Benedict
Unread 21-05-2008, 17:59
AdamHeard's Avatar
Lead Mentor
Well, to install a FP or other 540/550 series motor you just need to press the appropriate pinion onto the motor, dissemble the gearbox, and then reassemble with the new motor. To use them reliably there are some other steps as well.
From my experiences with the banebots, you absolutely need to make sure the output shaft stays in alignment. If not, the final stage of planets will be unaligned and seize up. I would also stay away from the higher reductions of the gearbox (256:1) as they can damage themselves under stall conditions.
Unread 21-05-2008, 18:06
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
From my experience and gained knowledge of banebots and FPs, I'd design to avoid stall conditions for both (especially with higher reduction transmissions) if at all possible.
Unread 21-05-2008, 20:12
I can confirm that Adam is correct in that we used this product from Banebots:
MP-42064-550 64:1, 42mm Planetary Gearmotor, RS-550 Motor
2008 Website Excellence Award
2008 Galileo Division Finalist, huge thanks to Teams 254 and 384!
2008 Galileo Division: 2nd ranked team
2008 Los Angeles Winner, huge thanks to Teams 330 and 980!
2008 Los Angeles Delphi "Driving Tomorrow's Technology" Award winner
2008 San Diego Winner, huge thanks to Teams 968 and 294!
2008 San Diego Delphi "Driving Tomorrow's Technology" Award winner
Team Website
Unread 21-05-2008, 20:46
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Yeah, we brought many replacement fp's for our winch to SVR and to Atlanta, but we never had to change them out. We had never used fp's before, and we read all sorts of horror stories about them blowing on CD. They are great motors to work with if you use them properly.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 22-05-2008, 13:12
Grant Cox's Avatar
Grant Cox Grant Cox is online now
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
I realize the thread has somewhat digressed, but I just wanted to point out how much I loved this bot and team. Working with them and playing against them in Atlanta was so much fun. One of the friendliest drive teams/coaches I've ever had the pleasure of working with, and a phenomenally designed robot to boot. Seeing you guys coming up at the last second to descore our place in the Galileo elims was one of the moments this year I remember most
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 22-05-2008, 13:16
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Yeah, for winches, FP would be my choice (unless CIM's are available obviously). On 269, we used FP quite often for elevator winches and robot lifting winches (in 07). I don't recall ever blowing one, but they do get awefully hot sometimes.
Our 2005 robot had an arm on top of an elevator, and we lifted the elevator with 2 FP motors.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
pic: Team 1023 2008 Robot Pic 1 DGrohnke1023 Robot Showcase 7 26-03-2008 20:01
pic: Team 177 - Bobcat 2008 Eric O Robot Showcase 9 26-02-2008 22:19
pic: Team RUSH 2008 ajlapp Robot Showcase 5 21-02-2008 18:24
pic: Team RUSH 2008 Jimmy Holmes Robot Showcase 4 20-02-2008 21:25
pic: 1086 team Picture 2008 JAZAD1 Robot Showcase 3 20-02-2008 14:40
