Go to Post FIRST, grant me the serenity to accept the things I cannot drill, Courage to drill the things I can, And wisdom to know the difference. - Bill_B [more]
Unread 21-05-2008, 15:22
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Maintaining power to a car FM transmitter
i know that on our boat, the 12v sockets give out momentarily when the engine starts simply because the starter draws too much current causing the voltage to drop.
Unread 21-05-2008, 19:16
DonRotolo's Avatar
Back to humble
FRC #0832
Actually, most lighter sockets cut off when the starter is engaged, to protect the equipment connected from the wild voltage transients that come from engaging a highly inductive kilowatt-plus load.
Anyway, to the problem: A simple solution is to make a fortifier. The cigar plug goes through a single diode (1N400x) in the + lead, then to a 12 volt rechargeable battery. A very small battery, smallest you can find. A large capacitor (Rated to 16 volts min) would work, too. The battery or cap is connected across the input, and also leads to your device.
Let me know if you need a wiring diagram or some suggestions for batteries. It should all fit inside a 2x3x5 Radio Shack project box, one end is a cigar plug, and a socket is mounted to the box, so you can use it for anything.
Don
transmitter configuration gabrielse Programming 0 06-05-2008 13:17
transmitter question??? mechanicalbrain Control System 1 23-04-2005 16:55
What Power Wheels car is the Fisher Price From? sanddrag Motors 1 06-02-2005 17:53
Maintaining a team Stephen Kowski Team Organization 7 10-10-2004 21:56
Car Audio on a Cart - Alternatives to Battery Power? DanL Electrical 28 04-02-2004 11:56
