Go to Post As a team sponsor, we are more concerned with the behavior, attitude and commitment to FIRST ideals than specific performance in the competition. Some of our teams perform well, some struggle, some are in the middle. We support them all in every way we can. - Chris Fultz [more]
Unread 23-05-2008, 04:15
fireball3004's Avatar
fireball3004 fireball3004 is offline
James Davis
AKA: James Davis
FRC #2090 (Punahou Robotics)
Team Role: Animator
fireball3004 is an unknown quantity at this point
Send a message via AIM to fireball3004
Re: How should I approach modeling?
Warning: I'm a noob.
Usually I use box modeling, but for this one I don't think that's such a great idea, I say this because I find making cylindrical objects like arms, or imperfect spheres like heads is the best aplication for Box Modeling.
I don't know how to uses spline cages, so I don't ask.
I would suggest you make 2 spheres for a head and body, 4 cylinders for legs and arms, work with them a bit then fuse them all together, and make them a editable poly... then get to work with the ears, eyes, ect.
Newbies away
Unread 24-05-2008, 18:12
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Ok bud I will help you out. Through a series of steps and guides.
1. Change the graphics mode to Direct-x in 3ds max. It handles actively rendering the textures in the view ports better.
2. Create to planes that will serve as to show the picture of the object you are trying to create. One plane will show a front view. The other will show the side. Apply the pictures to them through a material and check mark the show in view port box. Right click on the planes and go to properties, uncheck the renderable box and then uncheck the show frozen in gray box. Now check freeze box and click ok. These are your guides.
3. Create a plane in the middle of the head. Apply edit poly then symmetry modifier. Now in the edit poly modifier choose the segment option and now you can hold shift and drag out polys where you need them. If you need to slice polygons you will want to right click and choose the cut tool. Don’t use the slice plane or quick slice.
4. Create the basic shape of the head and body. Then refine it from there. You will want to create it in a series of passes. It’s all a matter of moving vertices and creating polys where you need them.
Rules to go by when modeling
1. Your faces should only have four sides. NEVER FIVE. And rarely three.
2. You need at least 3 slices at the joints in order for you mesh to move correctly.
3. Mesh smooth will NOT fix your model. Do not rely on it. You must make a model that looks good in the view port that you can skin correctly. Then you can apply a sub-division.
4. No 1,000,000 poly models. My ted boardmen model ran around 1,000 polys.
Make your model and post it here when you are done complete with a wire frame render and we will tell you what you need to fix. When you are ready for rigging I will tell you the procedure I go through to rig a character.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
How do you approach the design process? (+video) Bongle General Forum 2 22-04-2008 22:04
How Do We Approach Our School For Robotics Letters? Dorienne General Forum 21 27-07-2005 12:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
How do you approach your animation? Koko Ed 3D Animation and Competition 7 27-01-2003 21:42
How long should production time be??? archiver 1999 4 23-06-2002 23:16
