2008 Gyro
The pins on the 2008 gyro are labeled as follows:
G 5 R G 5 T B R W B R W /David To anyone struggling with the gyro, here's what I know: The second row (B, R, W) refers to the colors of wire (black, red, and white). The G and 5 refer to GND and +5V, respectively. Last edited by Nameless : 23-05-2008 at 02:07. |
Re: 2008 Gyro
T is for Twist
R is for Relative Temperature 200 Sensor Manual: http://usfirst.org/uploadedFiles/Com...sor_Manual.pdf |
Re: 2008 Gyro
Really, T is for Temperature, and R is for angular Rate. However, they screwed up the silk screening, so they are flipped.
Re: 2008 Gyro
For those that had good results from the gyro this year, did you use the code in for the temperature calibration?
We used WPILib this year, but did not attempt to incorporate the temperature calibration, and it worked okay, but could have been better |
Re: 2008 Gyro
What kind of applications do FIRST teams use temperature for generally?
Re: 2008 Gyro
Re: 2008 Gyro
Thanks for all the help and especially the link to the sensors manual.
/David |
| 2008 Offseason event MARC being moved to JUNE 28, 2008 | Steve Ketron | Off-Season Events | 10 | 21-03-2008 07:55 |
| Bad 2008 KOP Gyro - Need Replacement | taberski | Programming | 2 | 17-02-2008 05:37 |
| 2008 Gyro Code | FireJet | Programming | 13 | 14-02-2008 17:06 |
| 2008 Pre-Ship 2008 Suffield Shakedown Scrimmage Webcast | stevek | General Forum | 0 | 13-02-2008 23:55 |
| gyro | odin892 | Programming | 0 | 08-04-2003 09:59 |
