Go to Post Being called coach for the first time by some of my team. My dad was a football player and when I told him that story he teared up a bit. Me? A Coach? - MysterE [more]
Unread 23-05-2008, 18:51
Aren_Hill's Avatar
Build Nifty Things
Re: pic: 1625's shooter ready to fire
Originally Posted by Andrew141WOBOT View Post
So if I were to bump the wheel when it is loaded it wouldn't shoot?
You use a crab drive right?
you'd have to apply ALOT of downwards force on the linkage arms in order to fire it "accidentally". And yes we've got a 2 speed swerve drive
A guy who likes robots.
Unread 24-05-2008, 13:32
Aren_Hill's Avatar
Build Nifty Things
okay, heres how this thing works. In this picture the shooter is currently ready to fire.
there are two linkages, one hinged to the puncher itself and one hinged to the large sprocket, then connected together. Currently the forward force of the surgical tubing is holding the linkage quite tightly against a catch on the face of the sprocket. In order to fire the large sprocket rotates, moving the hinge point of the rear linkage over center and therefore there is no catch to stop the puncher from flying forward, hence it flies forward.
this leaves the shooter in "unloaded position but both linkages fully outstretched.
The large sprocket then rotates the same direction it did to fire, drawing back the rear hinge point hence partially loading the shooter. Then once the hinge point 180deg from where it was the catch grabs the linkage and it does another 170deg rotation, to be back ready to fire.
i hope thats not to confusing, i managed to explain it to people in person but alot of talking with the hands was involved
Unread 25-05-2008, 08:50
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
That shooter is very impressive. I watched you guys in some of your matches and I extremely impressed. I know this thread is about your shooter, but your drive train is incredibly cool as well. Do you have any pictures or CAD models that you can post of the drive train?
Unread 25-05-2008, 14:33
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Here are a couple links of pics already posted:
Single Module
Corner of robot focusing on a module
Unread 28-05-2008, 13:44
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
So, from where we are looking, the sprocket rotates counter-clockwise, the metal semi-circle that is attached to the sprocket hooks the bolt connecting the two bars and draws them back?
That's pretty neat. I like how this is all accomplished without pneumatics.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 28-05-2008, 13:55
Aren_Hill's Avatar
Build Nifty Things
its fully loaded at the moment, and you can see the catch holding the linkage back. So right now in order to fire it would rotate clockwise till the sprocket pivot point goes under the linkage, therefore passing center and allowing it to swing free.
The aluminum bolted to the sprocket is just to give the linkage a flat plane to slide on.
Unread 29-05-2008, 11:15
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
that is a wonderful design! I love Linkages Seems really simple too. Did you have any problem with the tubing?? Our team always had problems with it in our first year, so we never looked at it again haha! I suppose maybe we should... it helped make an amazing robot!
Unread 29-05-2008, 14:17
Aren_Hill's Avatar
Build Nifty Things
problems such as?
it was ziptied in place to whatever it went around.
Unread 30-05-2008, 11:14
FRC #1360
problems as in ripping and stretching... I saw a whole bunch of people using it this year so I'm going to assume in 2005 we had a bad batch or... we were really bad at using it haha
Unread 19-06-2008, 01:44
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Yeah that thing was a beast to play along side of in colorado. Just wish we wondent have fried our computer.lol. Hope to play along side u guys agian someday.
pic: 1625's swerve module (better pic) Aren_Hill Extra Discussion 25 22-07-2008 19:14
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
pic: IRI Fire Drill D.J. Fluck Extra Discussion 6 23-07-2006 21:23
pic: Fire in downtown Atlanta! artdutra04 Extra Discussion 13 04-05-2006 09:51
pic: Buckeye Fire Truck CD47-Bot Extra Discussion 15 01-04-2004 16:31
