Re: pic: Evolution of a gearbox rev 4
These renders are BEAUTIFUL! I mean, seriously professional quality work there.
Nice gearbox! Do you really need to support the output shaft of the CIM? Most, if not all, of the gearboxes that I have seen don't support it, which makes me wonder if it is necesary for you to support it in your gearbox.
It looks AMAZING! Great work.
To finish the whole thing you should definitely throw in the CAD of the bearings and hardware.
Very nice rendering! And it's even LASA purple!
Would I be correct in guessing that behind that center shaft you've got a fisher price motor through an AndyMark planetary? Looks like you guys could have a very nice setup next year. |
#7
Why is there a very small radius on the edges of the outer face of the outer plate?
That seems like it'd be a very time consuming process to cut. |
#8
It kind of looks like a chamfer to me. Could just be an aesthetic touch.
#9
Just a bit of aesthetics. The render did not look nice without it! I'm working on getting the main plate done the same way too.
| pic: Evolution of a Drivetrain | Drwurm | Extra Discussion | 1 | 10-02-2008 15:10 |
| pic: Front / Rear bearing saddles rev 2 | Andrew Schuetze | Extra Discussion | 14 | 31-12-2007 10:57 |
| pic: AM Supershifter mount / cntr axle saddle rev 3 | Andrew Schuetze | Extra Discussion | 7 | 28-12-2007 18:41 |
| pic: Mecanum Wheel Project - Rev. D | Madison | Technical Discussion | 17 | 07-08-2006 18:19 |
| pic: Mecanum Wheel Project - Rev. E | Madison | Technical Discussion | 8 | 13-07-2006 13:31 |
