Go to Post Just be yourself, be honest, and most importantly, be present. The best role models are the ones you can relate to. - Jessica Boucher [more]
Unread 26-05-2008, 17:27
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
Re: Best Drivetrain
Drive train: simplicity is key. keep your center of gravity low.we have used the same chassis for three years and it will except about anything you through at it. the past couple of years we have use a 4 wheel drive because it is simple and so versital.
also our programmer and figured out how to get crab to rotate so we dont need a turret.
If it isn't broken, Fix it till it is ~ Baker
Unread 26-05-2008, 17:42
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Best Drivetrain
I have actually been thinking about that. Couldn't you lock the wheels of a crab in a 4wd orientation and (if you have each side independently driven) just turn like a 4wd bot?
Has anyone attempted this?
-Vivek
"we don't build robots, we build people"
Unread 26-05-2008, 17:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Best Drivetrain
-Vivek
Yes, teams have done this before. Look at 111's swerve drive for a great example.
Swerves have a great deal of flexibility in how they perform and how they are built. Each configuration will result in different strengths and weaknesses.
Unread 26-05-2008, 19:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Best Drivetrain
-Vivek
You can do pretty much anything you can imagine with a swerve. Just if you have a coaxial like 148 or 118 where there's only one central gearbox providing power to all of the wheels you can't turn like a tank. With some tricky Programming and the ability to steer either side independently then you could turn in theory but it wouldn't be easy. My suggestion would be, if you have a vex kit you could prototype a bunch of swerve drives and try different motor configurations and control systems.
-Dustin Benedict
Unread 26-05-2008, 19:52
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: Best Drivetrain
That's not necessarily true. The reason 148 or 118 can't turn like a tank is because it has on central gearbox powering the entire drivetrain (not the rotation but the wheels). Coax crab can still be accomplished using two (or more depending on your preference) independent gearboxes that control the wheel nodes independently. If you only have one gearbox then regardless of programming you won't be able to turn like a tank.
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 26-05-2008, 19:57
AdamHeard's Avatar
Lead Mentor
Re: Best Drivetrain
If the wheels are steered separately in pairs, one pair can be turned 180 and steering in place is possible.
Unread 26-05-2008, 20:07
Mechanical Engineer
Re: Best Drivetrain
Right, exactly. You also don't necessarily need to limit them to 180 degrees of rotation (I understand the argument of why you would I'm playing devil's advocate). You could use a coaxial style setup (shaft inside of shaft) and run two sides of the robot independent of each other. In that case you are still doing a 'crab drive' as we have coined the term. The difference being the two sides are independent of each other rather than being run all off the same rotator and power transmission.
2010 and Beyond
Unread 26-05-2008, 20:35
thefro526's Avatar
Mentor for Hire.
Re: Best Drivetrain
lol that's what I said earlier, but it's still only spinning in place.
-Dustin Benedict
Unread 27-05-2008, 14:27
Aren_Hill's Avatar
Build Nifty Things
Re: Best Drivetrain
-Vivek
We did, We had one gen2 driving the front two wheels and one on the back two. So if we wanted to "tank drive" we just pointed the wheels sideways and drove around like a wide bot (wider=less effort to turn). This setup also enabled us to create "drift" buttons, We had 2 buttons on the joystick base and each one cut power to the respective transmission. So when we were going sideways we could kill a gearbox and the other one would drag its end around. This enabled us to effectively reorient on the fly, which greatly decreased our lap time.
A guy who likes robots.
Unread 03-06-2008, 23:41
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Best Drivetrain
I was wondering, what if you leave omni's in the front and put one dewalt to each of the remaining wheels. Direct drive or chain drive???
R.C.
MadTown Robotics Team 1323
Unread 03-06-2008, 23:50
Aren_Hill's Avatar
Build Nifty Things
Re: Best Drivetrain
I'm guessing your talking 6wd? If so this would create a very robust drive if done correctly, yet i suggest you mechanically link the driven wheels on each side so if one set is off the ground all the power still is driving the wheel touching the ground. I believe RUSH 27 has used a similiar setup before, at least in '06.
Unread 03-06-2008, 23:59
R.C.'s Avatar
Re: Best Drivetrain
So youre saying to power each wheel but link them by using chain and would this style of drivesystem be more effecient than the standard gearbox on each side thing
R.C.
Unread 04-06-2008, 00:12
Re: Best Drivetrain
I'm not sure about efficiency, but you don't have to worry as much about putting, say, 2 CIMs into one DeWalt. On the other hand, you just added 2 DeWalts to your robot, which adds weight. (Assuming a 6WD.) You may gain efficiency (fewer gears in interface) or lose it (chain slop, twice the gears for the same amount of power). You have a fully redundant drive system, though; theoretically, any one motor can power the entire side even if the other motor's gearbox explodes all over the field.
Unread 04-06-2008, 00:16
R.C.'s Avatar
Re: Best Drivetrain
It still wouldn't be as much weight as a supershifter and i remember that rush got up to 18 to 20 feet per second with drive system and Erich, you are right about the slight chance of losing efficiency
R.C.
Unread 05-06-2008, 14:32
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Re: Best Drivetrain
Now I've done searches, but I've never seen any team attempting a "ball drive" drive train. It might be under a different name, but it's simply a drive train that uses spheres for wheels. I've tried to think of a few ways of doing this, but because I have no examples to follow I can't say any of my ideas would work.
With spheres you could rotate the ball in different directions without having to rotate the thing that holds the ball inplace. The ball wouldnt have to be a complete sphere.
Has anyone tried to do this successfully?
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 27-01-2007 16:11
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
