Go to Post Speaking about healthier, the Texas air was sooooooooo much cleaner than NJ air, I felt my life expectancy being extended another 5 years. - The Chinese Guy [more]
Unread 26-05-2008, 21:38
ttldomination's Avatar
Sunny
Types of Metal
Hello All,
My team uses 80-20 and like 99% of our robot is 80-20. Now, in the past years we've been heavy and it seems like our metal is heavy 80-20 is strong but we are looking into other options.
I would like to know what kind of metal do you guys use? Besides 80-20.
1648: 2013-2014
5283: 2015
Unread 26-05-2008, 21:41
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Types of Metal
this year since we couldnt afford enough 80/20, we used 3/4 inch square box aluminum and filled it with plastic. worked perfect
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: Types of Metal
ttldomination,
Generally, you can't beat the strength to weight ratio of Mithral. That stuff is tough! Your robot will be able to withstand just about anything you can throw at it (or stab it with).
-ComradeNikolai
I cut myself shaving with Occam's razor.
Unread 26-05-2008, 21:42
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Types of Metal
I would recommend the kit bot frame. It isn't as adjustable as 80/20 or ITEM or anything like that but it is adjustable enough and you can modify it pretty easily too. No welding required, just some bolts and some bolts and Loctite.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 26-05-2008, 21:43
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Types of Metal
Our team used to use 80-20 but switched off of it for weight issues. We now use one-inch extruded aluminum (I don't know a specific maker) for most of our robot. Several high strength needs still use 80-20, but extruded forms almost all exterior parts of our robot. It has been very strong despite being hollow on the inside (we don't fill it).
Edit: We do use kitbot frame for the core of our robot. It has been proven strong, and allows us to have a working frame first week.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 26-05-2008, 21:53
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Re: Types of Metal
We've had a lot of success the past two years using standard 3/4 in wide, 1/16th in wall aluminum tubing. It's certainly not adjustable without making your own holes, but it is very light, very strong, and very easy to work with. You can use hacksaws and hand drills to build the robot if you want to.
In 2007 Mark Johnson, one of our mentors, did the welding, while in this past year we used screws for initial construction, and then replaced as much of the screws as possible with glue and rivets. (though much of the robot is still held together by screws, for lack of time).
We've used 80/20 in the past, and the problems we had with it were weight and at least I personally never felt like the bolts and sliders held together quite as well as a good bolt and locknut or even screws. However this is just based on feeling, we didn't really have an issue with that. It's very nice for areas that need a lot of adjustment, so don't rule it out altogether.
The kitbot frame is also pretty decent for the most part. You can easily make a very successful robot out of it.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 26-05-2008, 23:18
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Types of Metal
What kind of glue and on what parts/materials were you using it?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 26-05-2008, 23:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Types of Metal
80/20's main advantage is that it requires little effort to make many different designs with it. It is not a very efficient shape as far as it's strength/weight ratio.
If you want to spend more time designing, you should look into using many other sections of aluminum, as well as other metals and non-metals. Steel can be very effective (look at 1501's 2007 robot), sheet aluminum is also used by them to make strong, light structures. We've used fiberglass pultrusions for our frame, and 842 uses it for their entire robot! Some teams use plywood, you could use spruce, or other woods, which take some effort to design but are relatively easy to work with and can be very strong and light (think of the early airplanes, which were made almost entirely of spruce). For aluminum, look into tubing, both round and square, and angle and sheets. Our robot used sheet and angle aluminum this year.
Also look at the various ways you can connect the parts. Rivets are great, they are light, strong, and quick to replace if needed. Bolts and nuts are a bit heavy and cumbersome, but can be removed and replaced many times. Glues are a bit tricky to apply and hard to repair joints made with them, but for some joints they are the best way to go. Welding is great for thicker alumimum parts, and for thinwall steel tubing (such as 1501 has used).
Unread 26-05-2008, 23:47
Herodotus's Avatar
AKA: David Resowski
Re: Types of Metal
It was a polyurethane based glue I'm pretty sure, but I don't know exactly what kind or brand of glue. I'll be in the shop Wednesday and if we still have the container of it I'll post back with more detail. We used it on 3/4 inch extruded aluminum tubing held together by flat plates. Before we did any gluing we roughed the surface up with a pneumatic disc grinder to create a surface for the glue to actually stick to.
We never had any of our glued pieces fail, and when we just glued two test pieces together and tried to break the joint we bent the metal before we did anything to the glue itself. We could easily have gotten away with not using the rivets, but we just used them to hold the pieces together till the glue could set.
Of course, don't get it on your hands... or clothes. The other problem I could see is if it is in a high stress location and the part it's holding on is damaged it would be a real pain to fix.
Unread 26-05-2008, 23:48
Engineering Mentor
Re: Types of Metal
Cool, I'd definitely be interested to know the details on that. Our team has never tried glue for joining metal to metal before.
Unread 26-05-2008, 23:59
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Types of Metal
Originally Posted by ComradeNikolai View Post
ttldomination,
-ComradeNikolai
Yeh, too bad the balrog destroyed the mine
We used 1/8" 1x1 and 1x3 this year (ack, heavy!).
We will most likely switch partially to 1/16".
Kitbot chassis with modifications of course.
-Vivek
"we don't build robots, we build people"
Unread 27-05-2008, 00:08
Aren_Hill's Avatar
Build Nifty Things
Re: Types of Metal
1x1x1/16th box tubing for the entire frame and lots above that. aside from that we use alot of 1x1x1/16th angle, all aluminum of course.
A guy who likes robots.
Unread 27-05-2008, 00:13
Re: Types of Metal
Nah, just the access is blocked. Without the Balrog, it's wide open.
Mithril may, however, fall under the metal type Unobtanium.
Kit frame, or if you like custom, 1" by 1"-2" by 1/8" wall tubing is pretty good for a drive frame. Higher up, 1/16" wall works well. Thing about the drive base is, it takes a beating even with the bumpers, so 1/16" wall might not be the best option. (Then again, properly braced and with a decent material on top, 1/16" can support a robot climbing on top of it, so...)
Unread 27-05-2008, 00:37
Herodotus's Avatar
AKA: David Resowski
Re: Types of Metal
I believe we only used 1/8th wall thickness in four pieces of the base frame, those being the four blocks that the axle( a dead axle) for the wheels go through. We did have one incident at Western where we hit the wall and bent our entire frame, but we fixed it, and then glued a solid piece of diamond plate at the weak point to give it a little more structure, without too much weight increase. If we had just incorporated a few triangles into the base in the first place it probably wouldn't have been an issue at all.
Unread 27-05-2008, 01:00
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Types of Metal
3/4"x3/4"x.035" Chromoly Steel (Available at Aircraft Spruce) is wonderful if you can weld (not as tricky as aluminum i don't think).
You can use 1/2"x1/2"x.035" as well for areas under less stress. The stuff is super light, (about the same as aluminum), more compact than 1"x1"x1/8" box aluminum, and three times as strong. Cost is the only downfall but it isn't anything too unrealistic. Teams 269 and 1501 tend to work with this stuff and both come out with VERY solid frames.
ITEM is a similar solution to 80-20. Don't have a source but I've heard it is stronger than 80-20 as well.
Other than that, on 171, we use Kit of Parts frame and 1"x1"x1/8" or 1"x2"x1/8".
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
[OCCRA]: Types of metal rdudek OCCRA Q&A 1 20-10-2006 16:01
Gear Types Joe_Widen Technical Discussion 16 02-06-2006 11:46
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
Music types Carolyn Duncan Chit-Chat 42 03-08-2001 23:06
