Go to Post The solution to that "problem" is obvious: practice driving. - Alan Anderson [more]
  #151   Spotlight this post!
Unread 26-05-2008, 17:45
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Best Drivetrain
Originally Posted by vivek16 View Post
I have actually been thinking about that. Couldn't you lock the wheels of a crab in a 4wd orientation and (if you have each side independently driven) just turn like a 4wd bot?
Has anyone attempted this?
-Vivek
Yes, teams have done this before. Look at 111's swerve drive for a great example.
Swerves have a great deal of flexibility in how they perform and how they are built. Each configuration will result in different strengths and weaknesses.
  #152   Spotlight this post!
Unread 26-05-2008, 19:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Best Drivetrain
-Vivek
You can do pretty much anything you can imagine with a swerve. Just if you have a coaxial like 148 or 118 where there's only one central gearbox providing power to all of the wheels you can't turn like a tank. With some tricky Programming and the ability to steer either side independently then you could turn in theory but it wouldn't be easy. My suggestion would be, if you have a vex kit you could prototype a bunch of swerve drives and try different motor configurations and control systems.
-Dustin Benedict
  #153   Spotlight this post!
Unread 26-05-2008, 19:52
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: Best Drivetrain
That's not necessarily true. The reason 148 or 118 can't turn like a tank is because it has on central gearbox powering the entire drivetrain (not the rotation but the wheels). Coax crab can still be accomplished using two (or more depending on your preference) independent gearboxes that control the wheel nodes independently. If you only have one gearbox then regardless of programming you won't be able to turn like a tank.
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
  #154   Spotlight this post!
Unread 26-05-2008, 19:57
AdamHeard's Avatar
Lead Mentor
Re: Best Drivetrain
If the wheels are steered separately in pairs, one pair can be turned 180 and steering in place is possible.
  #155   Spotlight this post!
Unread 26-05-2008, 20:07
Mechanical Engineer
Re: Best Drivetrain
Right, exactly. You also don't necessarily need to limit them to 180 degrees of rotation (I understand the argument of why you would I'm playing devil's advocate). You could use a coaxial style setup (shaft inside of shaft) and run two sides of the robot independent of each other. In that case you are still doing a 'crab drive' as we have coined the term. The difference being the two sides are independent of each other rather than being run all off the same rotator and power transmission.
2010 and Beyond
  #156   Spotlight this post!
Unread 26-05-2008, 20:35
thefro526's Avatar
Mentor for Hire.
Re: Best Drivetrain
lol that's what I said earlier, but it's still only spinning in place.
-Dustin Benedict
  #157   Spotlight this post!
Unread 27-05-2008, 08:52
Andrew141WOBOT's Avatar
Andrew141WOBOT Andrew141WOBOT is offline
WOBOT for Life
AKA: Andrew
FRC #0141 (WOBOT)
Andrew141WOBOT is an unknown quantity at this point
Re: Best Drivetrain
It really depends on the game... our 2008 bot drove like a car. 2 Cims, direct drive, to each rear wheel, with an electrical differential. The front wheels drove used the acrynom principal, so when the bot was turning left, the Left front wheel turned more than the right. It was really strong this year, but it probably won't for any other game.
  #158   Spotlight this post!
Unread 27-05-2008, 12:37
Re: Best Drivetrain
Ackerman principle, not acronym principal.
  #159   Spotlight this post!
Unread 27-05-2008, 14:27
Aren_Hill's Avatar
Build Nifty Things
Re: Best Drivetrain
-Vivek
We did, We had one gen2 driving the front two wheels and one on the back two. So if we wanted to "tank drive" we just pointed the wheels sideways and drove around like a wide bot (wider=less effort to turn). This setup also enabled us to create "drift" buttons, We had 2 buttons on the joystick base and each one cut power to the respective transmission. So when we were going sideways we could kill a gearbox and the other one would drag its end around. This enabled us to effectively reorient on the fly, which greatly decreased our lap time.
A guy who likes robots.
  #160   Spotlight this post!
Unread 03-06-2008, 23:41
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Best Drivetrain
I was wondering, what if you leave omni's in the front and put one dewalt to each of the remaining wheels. Direct drive or chain drive???
R.C.
MadTown Robotics Team 1323
  #161   Spotlight this post!
Unread 03-06-2008, 23:50
Aren_Hill's Avatar
Build Nifty Things
Re: Best Drivetrain
I'm guessing your talking 6wd? If so this would create a very robust drive if done correctly, yet i suggest you mechanically link the driven wheels on each side so if one set is off the ground all the power still is driving the wheel touching the ground. I believe RUSH 27 has used a similiar setup before, at least in '06.
  #162   Spotlight this post!
Unread 03-06-2008, 23:59
R.C.'s Avatar
Re: Best Drivetrain
So youre saying to power each wheel but link them by using chain and would this style of drivesystem be more effecient than the standard gearbox on each side thing
R.C.
  #163   Spotlight this post!
Unread 04-06-2008, 00:12
Re: Best Drivetrain
I'm not sure about efficiency, but you don't have to worry as much about putting, say, 2 CIMs into one DeWalt. On the other hand, you just added 2 DeWalts to your robot, which adds weight. (Assuming a 6WD.) You may gain efficiency (fewer gears in interface) or lose it (chain slop, twice the gears for the same amount of power). You have a fully redundant drive system, though; theoretically, any one motor can power the entire side even if the other motor's gearbox explodes all over the field.
  #164   Spotlight this post!
Unread 04-06-2008, 00:16
R.C.'s Avatar
Re: Best Drivetrain
It still wouldn't be as much weight as a supershifter and i remember that rush got up to 18 to 20 feet per second with drive system and Erich, you are right about the slight chance of losing efficiency
R.C.
  #165   Spotlight this post!
Unread 05-06-2008, 14:32
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Re: Best Drivetrain
Now I've done searches, but I've never seen any team attempting a "ball drive" drive train. It might be under a different name, but it's simply a drive train that uses spheres for wheels. I've tried to think of a few ways of doing this, but because I have no examples to follow I can't say any of my ideas would work.
With spheres you could rotate the ball in different directions without having to rotate the thing that holds the ball inplace. The ball wouldnt have to be a complete sphere.
Has anyone tried to do this successfully?
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 27-01-2007 16:11
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
