Go to Post I don't even consider FIRST to be an extracurricular anymore; it is a way of life. - Jaine Perotti [more]
Go Back   Chief Delphi > Announcements
  #166   Spotlight this post!
Unread 28-05-2008, 21:58
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: SolidWorks Robotics Summer School
I mate a screw to the square hole and then the standoff to the screw, so 3 mates on the screw 2 on the standoff.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #167   Spotlight this post!
Unread 28-05-2008, 22:36
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Yeah but how do you mate the screw to the square hole.
  #168   Spotlight this post!
Unread 28-05-2008, 22:46
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
aby one want to send me a dvd drive for my computer..
Curie..
  #169   Spotlight this post!
Unread 28-05-2008, 23:30
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
dose anyone know if they meet 1000 people yet?
  #170   Spotlight this post!
Unread 28-05-2008, 23:54
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
The way I deal with the Square Hole, round peg issue is I add a point to the center of the square hole (this can be done many ways, I prefer to use the 3 point arc tool and make an arc where the 3 defining points are the midpoints of three edges of the square hole. You can also draw a perpendicular bisector from the one edge to the opposite edge, and the midpoint of the bisector segment is the center of the hole, etc)
Once you have the hole in the center, you need to add an axis. Insert-> Reference Geometry -> Axis. You will select the center point, and the plane/face that the square hole is on. It should automatically draw the axis, but if it doesn't, basically you want to use the axis generation mode where you select a point on the axis and a plane perpendicular to the axis.
So that's how you can get your screw or standoff aligned. Then you can do a Coincidence mate on the face of the plate and the back of the screw/standoff to fix it onto the plate. This constrains the entire piece except for it's rotation in the hole, which really shouldn't be important.
  #171   Spotlight this post!
Unread 29-05-2008, 14:35
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Originally Posted by Adam Y. View Post
Wow. I finally figured out the best way to make the Vex Standoffs to the Vex frame. If someone shows me a way to do it with less than three mates I think I might cry.
Adam
I believe you are talking about square shafts and square holes. This has been an issue. SolidWorks recreated all VEX components from the VEX Starter Kit for Square Bot and they are posted on www.3dcontentcentral.com. Search for the parts with a May 25, 2008 or later creation date such as Shaft-3000 and VL-PLATE-5-15 Rev A. You will see that these components have Axis build down the center of Square Holes and the parts have what are called Mate References. Mate Reference allow you so select coincident of concentric geometry when you insert a new part into the assembly - like Toolbox components. I can get your mates down to two or even one depending on the position in the assembly because the new VEX parts in SolidWorks are very smart. These are competition standard, materials have been assigned and mass has been confirmed with the physical shape of Square Bot components.
Marie
  #172   Spotlight this post!
Unread 29-05-2008, 14:58
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
did anyone else have a problem installing cosmos?
my says Error 1406
  #173   Spotlight this post!
Unread 29-05-2008, 14:59
Adam Y.'s Avatar
Adam Y.
no team (?????)
Originally Posted by mplanchard View Post
Adam
Marie
Actually, I was refering to the standoffs that you mate to the square hole though it seems like the same solution. I ended up cheating and prayed to design gods that the standoffs were symetrical. I ended up constraining the part using two symmetry constraints. I will try using the reference geomtry that I see in your videos. Also, is there any form of collision detection in Solidworks? I have a model of the Vex tank tread but I ended up jumbling it up into one giant mess of collisions.
  #174   Spotlight this post!
Unread 29-05-2008, 15:26
For Collision Detection - select Move Component from the Assembly toolbar. Select "Collision Detection". Choose the option "These Components" and review the other options if appropriate.
Sometime I find also find it help to use Tools, Interference Detection. This shows me the volume of interference between components
Marie
  #175   Spotlight this post!
Unread 29-05-2008, 15:42
We are well over 1000 still fulfilling requests until we get to 2000. Demand has been high.
Also, you will be sent two emails after you install the product. One to license SolidWorks. This is a long number, copy and paste this when prompted. Make certain you have the DWG icon and the eDrawing icon on your desktop.
You will receive a second email, this contains the license data file for COSMOS. Refer to the instuctions on the installation card. You will also need your computer address. Marie
  #176   Spotlight this post!
Unread 29-05-2008, 23:17
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
o thanks i just i read it full next time
  #177   Spotlight this post!
Unread 01-06-2008, 08:07
Dr. Osemwengie's Avatar
Dr. Osemwengie Dr. Osemwengie is offline
Founder and President
no team (Open Robotics University)
Dr. Osemwengie is a jewel in the roughDr. Osemwengie is a jewel in the roughDr. Osemwengie is a jewel in the rough
I think coaches should be allowed to participate in SolidWorks Robotics summer School, just as PTC allowed coaches to participate in their Pro/Engineer summer boot camp. If coaches know how to use a program, students in their teams are more likely to use the learn software.
  #178   Spotlight this post!
Unread 02-06-2008, 07:47
Any coach, mentor or teacher can participate in Robot Summer School. We have over 50 mentors registered for the program. In fact we have two additional programs for teachers:
1. For all instructors - engineering, math, science, technology, robotics etc. - SolidWorks STEM Teacher Grant www.solidworks.com/stemgrant. Here teachers can received professional development points, SolidWorks certification exam - but the instructor must supply a lesson to our teacher blog to share at http://blogs.solidworks.com/teacher to share with other teachers,
2. SolidWorks First Teacher program. This summer program is between the industry mentor and a teacher involved in robotics. SolidWorks will provide the teacher 1 - 5 month copy of Commerical SolidWorks to work at their industry mentor facility for the summer. www.solidworks.com/firstteacher.
Marie
  #179   Spotlight this post!
Unread 03-06-2008, 13:11
SolidWorks Robotics University is now live and Summer School has started. For those that registered, you will receive an email from me today. Check your Junk Mail box just in case you have filters on.
Review a lesson on my blog, check out a featured robot, add photos, videos, invite a friend and have fun.
Thank you for participating in the program.
Marie
  #180   Spotlight this post!
Unread 03-06-2008, 16:37
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
what would the website be? Because its not solidworks.com/robotics because thats still displaying the same stuff as before.
Sorry I'm a little too impatient to wait for the email.
SolidWorks First Teacher Summer Internship Brandon Martus Announcements 1 10-03-2008 16:41
SolidWorks-designed ‘bots win FIRST Robotics and BattleBots IQ competitions Elgin Clock SolidWorks 1 03-07-2007 01:58
Summer Robotics Courses Nitroxextreme Career 3 11-01-2006 00:44
NASA Summer High School Apprenticeship Program dlavery Career 5 17-07-2004 12:13
Summer Robotics Pengiun Joe General Forum 15 17-07-2002 22:17
