Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 29-05-2008, 02:32
knine143 knine143 is offline
FRC #1047
knine143 is on a distinguished road
Compass tilt error
Hey all.
We are doing a competition which involves GPS navigation, and would like to integrate a compass into our system.
Are there any digital compasses that are not affected by tilt?
We purchased the Devantech CMPS03 compass, but it is affected by tilt. Sometimes our robot will be on a slope, and it still must have consistent readings from a compass.
Unread 29-05-2008, 06:54
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Compass tilt error
AFAIK, all compasses are affected by tilt.
You could put the compass on a tilting platform. As long as the CG is (well) below the pivot point, your compass will always be level with the ground.
Unread 29-05-2008, 07:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You should set your compass into a 2 axis gimbal like this.
They are fairly easy to create as long as you keep your CG below the 1st axis pivot point and centered on the 2nd axis.
___________________
- Tennyson, Ulysses
Devantech CMPS03 compass sensor eagleslg Programming 1 24-05-2008 22:00
Gyro Compass Nathan Programming 5 16-01-2008 14:55
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
Political Compass Joshua May Chit-Chat 11 01-10-2004 22:32
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
