Go to Post Intent is determined by those that are doing, not those that are watching. - meaubry [more]
Unread 29-05-2008, 22:47
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Dashboard: how to calculate battery voltages?
Hello,
I have been hacking on a small VB app to connect to the dashboard port during matches to record every packet into a CSV file for analysis in Excel. It's a handy little tool, but I'm looking to extend its functionality.
For now, I can't figure out how to calculate, given the 1 byte battery voltage, the actual number of volts. Is there some magic formula I must run the byte through to get the proper voltage?
Thanks.
BTW, I may release this app once it's a bit better. Right now it's just a mash of code I wrote last-minute...I really needed it to figure out why our auto-correction in auton wasn't working.
JBot
Aren't signatures a bit outdated?
Unread 29-05-2008, 23:09
Re: Dashboard: how to calculate battery voltages?
I have no way to test if this helps you, but I found this in ifi_aliases.h It leads me to believe that you should scale the readings you get back by the same amount as IFI does in this code.
 *---------- Aliases for Battery Voltage bytes --------------------------------------------------------
 * Formula to calculate voltage in volts:
 *     current_voltage = battery_voltage * 0.038 + 0.05;
#define battery_voltage     rxdata.rc_main_batt*15.64/256
#define backup_voltage      rxdata.rc_backup_batt*15.64/256
how do i calculate degree/pwmstep? Ianuser Programming 0 17-02-2007 09:58
How to calculate arm angles? SoD Programming 5 31-01-2007 14:17
How to calculate planetary gear ratios? sanddrag Technical Discussion 2 27-02-2005 11:55
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
Battery Voltages in Dashboard Ian W. Programming 10 07-03-2004 16:50
