Go to Post But you are an influencer: Use it for good. - DonRotolo [more]
  #31   Spotlight this post!
Unread 30-05-2008, 23:59
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Worst Moments in Team History
every time a loose screw or loose electrical connection kills the robot and you loose a match as a result. Losing to a better team is no big deal compared to a preventable mistake taking you out of the match.
2016 Central Illinois Winner. Curie Division finalist
  #32   Spotlight this post!
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I've related this elsewhere, but it probably bears repeating. In 2007, we primarily focused on being a rampbot and GLR was our first regional. For various reasons we didn't get a lot of practice in on Thursday, but we were confident in our ramps, as they worked very well in a few tests at the shop. Sadly, we were using the infamous 1:125 Banebot trannies with FP motors. Predictably, we stripped out the carrier plates and were pretty much useless on Friday. We managed to get the things welded together that night and won all our Saturday morning matches thanks to some fairly impressive lifting. We all crossed our fingers during the draft, and ended up completely overlooked by all the teams thanks to poor Friday.... Except for 1114 and 67, who picked us for the #1 alliance. You're probably wondering where the bad part is, but rest assured, I'm almost there. Our alliance completely trounced #8 in the quarters. Then came the semis. Semi 1, our robot inexplicably twitched about ineffectually and we lost the match, barely. I'm uncertain of the reason to this day, but I suspect we were bit by a "charged" battery that failed to make good contact with the charged. We spent entirely too much time chasing it as a radio problem that we barely had time to swap in a fresh battery and get out for Semi 2. We ended up just strapping our battery in and running without a rear bumper. Unfortunately, our battery strap wasn't particularly up to spec and it was apparently our bumper that was holding our battery in all weekend. So when an opposing robot hit us with a decent block, our battery flew completely out the back of our robot, leaving us dead on the field. 1114 and 67 put up a good fight and we only lost the match by a tube, but it was obviously our shortcoming that lost us the regional.
I'll probably live it down someday in the future when I manage to stop posting about it annually, but I still swear I'll figure out some way to make it up to Karthik. Preferably not with a repeat performance on an opposing alliance, though.
And remember kids: Always strap your batteries!
  #33   Spotlight this post!
Unread 31-05-2008, 10:55
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Originally Posted by RoboGeek99 View Post
The worst things for us that happened this year as a rookie team is when 2 of members HAD to get out of the team because their band director wouldnt allow them to be in both robotics and band (They were both section leaders in the band). That left our rookie team with VERY few members but we pulled it off...barely
A similar situation happened to our team, but regarding the Kettering Rookie Competition this year: we had district large ensemble contests on the Friday of a Friday/Saturday competition in another state, and our director wouldn't excuse us to go to that (yet other things, such as vacations, are ok... but here's not the place). That left about half our team to go, without a programmer, as I am in band. Everyone boarded the bus to leave and then Friday morning, when they're all in Michigan, a snow storm hits; contest was cancelled, and, unfortunately, none of us could get to the competition... To make matters worse, I forgot to load the correct code onto the laptop they were taking for editing, and I accidentally sent the wrong code to them... needless to say, our coach (also a programming teacher) did lots of editing to the code.
I cut myself shaving with Occam's razor.
  #34   Spotlight this post!
Unread 31-05-2008, 12:33
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Originally Posted by dtengineering View Post
The worst moment for me occurrs annually, usually with about ten days left in build (quite often around Valentine's day...) when we are:
a) overweight
b) broken down
c) burned out
And that's just the robot....
Then we get over it, and move on, then come back for more the next year.
Jason
That is sooo funny and true.
Every year I say it is my last a few times during the season. My wife just doesn't believe me anymore.
Doug Leppard
  #35   Spotlight this post!
Unread 31-05-2008, 13:06
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I'm not quite so sure if our team has had any truly devastating moments in our team history. Sure, there have been low periods, but those are balanced out by the high periods.
I guess it all boils down to personal worst moments, which are actually pretty common. People get into fights, people think the refs were unfair, people create elaborate conspiracy theories, people are disappointed when they cant do something. The thing is though, these people usually don't let their negativity spread through the team, and instead still attempt to remain positive (except for a couple unnamed people).
So in general, even inner-team turmoil is not represented by the team as a whole.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #36   Spotlight this post!
Unread 31-05-2008, 13:15
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
From a robot perspective, the saddest thing to happen to us in team history was probably in Rack and Roll when one of our BaneBots gearboxes (loaded with two CIM's each) in a defensive robot were completely destroyed. The bad thing about this was that it happened at the second match of the Waterloo finals (the first of which we had won). The sad part was that our alliance partners had amazing robots and they wouldn't let us switch out...
The team however took away from this the lessons of prototyping and robust design; this year we designed a system where we could rip out an entire drive module and replace it in about 3 minutes.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
  #37   Spotlight this post!
Unread 01-06-2008, 06:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Boy, if the worst thing that ever happens to you is your robot not working right, or missing the eliminations, or losing in a manner that's hard to swallow, you're doing pretty darn well.
2001-2004: Team 100
2006-Present: Team 254
25 Great Moments in Robotics History George1902 Chit-Chat 0 14-11-2006 15:11
Infamous Moments in IRI Talent Show History Travis Hoffman Off-Season Events 18 04-08-2006 07:48
History of Team Spirit Steve Howland General Forum 29 20-01-2006 23:33
wacky moments for team 623 mechanicalbrain Robot Showcase 1 24-04-2005 13:18
pic: A Brief History of Team 188 CD47-Bot Extra Discussion 3 18-07-2004 21:12
