Go to Post As JFK said we did not do this because it was easy, we did it because it was hard. - Glenn [more]
  #31   Spotlight this post!
Unread 31-05-2008, 20:12
Lions for First's Avatar
Lions for First Lions for First is offline
AKA: Devan
FRC #2365 (Lions Robotics)
Lions for First has a spectacular aura aboutLions for First has a spectacular aura aboutLions for First has a spectacular aura about
Send a message via AIM to Lions for First
Re: Types of Metal
Originally Posted by Richard McClellan View Post
What place do you buy from, and how much does it typically cost?
its not my job to buy it so i dont know just ask someone on 842 (im sorry) but i do know its worth its mass in gold
2008 AZ Regional: Highest Rookie Seed
5th seed alliance Cap.
Semi-finalists (thanks 125 and 842)
  #32   Spotlight this post!
Unread 31-05-2008, 21:07
Billfred's Avatar
Billfred Billfred is offline
Re: Types of Metal
Originally Posted by IKE View Post
I was mistaking 80/20 for starbar.
I did some googling to no avail, since I haven't heard of it before: What is starbar?
  #33   Spotlight this post!
Unread 31-05-2008, 21:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Types of Metal
We've bought fiberglass pultrusion from Creative Pultrusions. shipping is a bit expensive....
http://www.creativepultrusions.com/
  #34   Spotlight this post!
Unread 02-06-2008, 10:48
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Types of Metal
Starbar may be a local nickname, It is a t-slot style aluminum extrusion bar that has special slot nuts and brackets. It is very versatile and many team use it for their frames because it is strong and easy to fabricate with. IMO it is crazy heavy though. Weight/ft is significantly higher than most other materials, but it is strong and if it saves you 1 week in the build season the weight penalty can be worth it.
Here is a link showing the cross section
http://www.aline1.com/products/?categoryID=16
When you see the cross section you get the nickname.
I know 494 used this through 2006. When I asked them why they sighted 2 weeks of practice with the robot. Hard to argue with that. We will likely stick to a sheet metal chassis, or a welded stickframe.
  #35   Spotlight this post!
Unread 03-06-2008, 13:11
Skifanatic's Avatar
Skifanatic Skifanatic is offline
AKA: Matt
FRC #0348 (NHS Robotics)
Skifanatic is an unknown quantity at this point
Send a message via AIM to Skifanatic
Re: Types of Metal
Our team used "Alumicore" for the plate where out arm was held. Alumicore is usually used to make outdoor signs. Its plastic sandwiched in between two 1/32 aluminum. Its REALLY light! the frame of our bot is made out of aluminum sheet and 80/20.
-2008 National FINALISTS
-2008 Curie Division CHAMPS
-2008 NYC regional FINALISTS
  #36   Spotlight this post!
Unread 04-06-2008, 00:23
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
Re: Types of Metal
A couple materials from this post are interesting to me and I would like to know where our team could buy them.
The 1X1X1/6" square tubing with the hole pattern as used by 1216 appears to be very useful and easy to work with. Does anyone have a source for this?
How about the Alumicore? When I google it, I find many sign companies. Does anyone have a source for this where we can get it before the sign companies mark it up?
For panels on our robot, we have been using 8mm Twin-Wall Polycarbonate Sheet material from Farmtek.com. It weighs 1.5 KG/m2 or about about 0.3 lb/sq ft.
  #37   Spotlight this post!
Unread 04-06-2008, 00:39
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Re: Types of Metal
Originally Posted by squirrel View Post
I'm pretty sure that 1501 welds their tubing, instead of brazing it.
Yep, using acetylene and oxygen. A nice warm job in the middle of winter. Took a while to get used to doing it, the thin walls made it hard not to make holes in the tubes. All part of the learning experience.
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
  #38   Spotlight this post!
Unread 04-06-2008, 08:18
Gdeaver Gdeaver is offline
FRC #1640
Re: Types of Metal
Team 104 used 8020 quick frame material this year. We used the EZ tube connectors. The quick frame tube is a good alloy and the anodizing gives a nice appearance. Cuts nice with a miter saw. It allows a frame to be made very quickly. No bolting or drilling for pop rivets. We bought the material from the 8020 ebay store and saved allot. We had no problems with the plastic fiber reinforced connectors. It's a viable option for low budget low skill teams.
This is a link for the connectors.
http://www.eztube.com/connectors/connectors.html
  #39   Spotlight this post!
Unread 04-06-2008, 10:48
MrForbes's Avatar
AKA: Jim
Re: Types of Metal
Gas welding thinwall steel tubing is challenging...fortunately once you learn how, you never forget (just like falling off a unicycle!)
I took a couple welding classes at the local community college back when, and patiently learned the techniques to weld thin steel with a torch. Then I got a MIG welder and never did it again...until last week when I had to fix the steer tube (top of the fork) on an old bike, and I decided to gas weld it, and it worked just fine.
  #40   Spotlight this post!
Unread 05-06-2008, 13:41
Re: Types of Metal
After several class sessions welding thin little plates with oxy-acetylene it was a revelation the day we tried the MIG welder for the first time. I remember thinking two things: 1. This is all? That's it? All you have to do is keep the wire moving?, and 2. Who wants to go back to gas welding?
  #41   Spotlight this post!
Unread 06-06-2008, 09:32
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Types of Metal
[quote=Bruce Newendorp;751402]A couple materials from this post are interesting to me and I would like to know where our team could buy them.
QUOTE]
When I talked to 1216 they bought 1x1x1/16 wall and then drilled it to a usefule size on a cnc mill. (you can email them to get more details). I know most of us don't have cnc mills so in the off season we will be making a drill guide out of 1/4 steel or aluminum. We made a couple of them for sheet metal stuff and it worked really well. If you use 1/4 architectural angle, you can make a nice drill guide by taking your time or on a conventional mill. do 1/8" holes and then clamp it to your box tube and any newbie can make a nice piece. Unclamp, slide, pin repeat. For some unkown reason this seems to go under the lightening hole mystery where kids love to drill lots of holes. File an edge, never! Drill lots of holes, yeah. A bit of caution: only drill through 1 side at a time otherwise you will get bit-walk with a thin drill. If you do this when the stock come in you will have a nice straight starting edge to work with.
  #42   Spotlight this post!
Unread 06-06-2008, 10:36
cooker52's Avatar
Cookie
AKA: Seth Cook
FRC #4272
Re: Types of Metal
Using hole patterns is what 1501 does best. We have found that the best way to make a hole pattern that lasts for half the build season is to have a nice piece of steel laser cut to make the hole patterns. The laser cutting hardens the metal around the hole, making it harder for the drill to distort (which leads to a lot of awkward holes).
They lasted us a while, and we drill thousands of holes a build season.
  #43   Spotlight this post!
Unread 06-06-2008, 11:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Types of Metal
[quote=IKE;751674]
QUOTE]
Another solution would be to press a drill bushing into each hole.
2001-2004: Team 100
2006-Present: Team 254
  #44   Spotlight this post!
Unread 08-06-2008, 11:14
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Types of Metal
drill guides work great, but can get a bit expensive ($10/guide). Aluminum patterns can wear out quickly. A cheap way to fix them is as they start to wear out drill them out and press in small piece of steel tubing. Significantly cheaper but not as nice as drill guides.
  #45   Spotlight this post!
Unread 10-06-2008, 17:42
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
Re: Types of Metal
team 270 uses the kitbot frame and secures another frame about 5 inches up from the main one out of 1x2 hollow box aluminum
its very strong
for most of our bot, we use box aluminum and plate aluminum and the occasional piece of plexi-glass or plastic lexan.
[OCCRA]: Types of metal rdudek OCCRA Q&A 1 20-10-2006 16:01
Gear Types Joe_Widen Technical Discussion 16 02-06-2006 11:46
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
Music types Carolyn Duncan Chit-Chat 42 03-08-2001 23:06
