Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 31-05-2008, 19:55
eagleslg eagleslg is offline
FRC #1047
eagleslg is an unknown quantity at this point
Calibrating Devantech cmps03
Hey all.
We purchased the devantech cmps03 for use on an autonomous outdoor robot for navigation purposes. We have wired it up as per directions and gotten readings by timing the pwm pulses. However, we are supposed to get readings within 3 or 4 degrees, but our readings are way off. They are pretty constant, but not at all the true direction. We figure this is due to calibration.
We followed the calibration directions in the manual and used the pin method. This changed the readings that the compass gave, but they are still highly inaccurate.
We are aware that tilt affects the compass readings and make sure to keep it level at all times.
Are there any suggestions as to how to calibrate the compass? Thanks
Unread 31-05-2008, 20:57
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Calibrating Devantech cmps03
Is it a scale error or an offset error? In other words, if you turn it 180deg, does the reading change by a value representing 180deg?
Unread 31-05-2008, 21:35
FRC #1047
No. For every ten degrees I turn it, it varies different amounts.
At least, that's what used to happen. Now, after attempting some calibration, it gives good readings between 60-270 and seemingly random readings from 270-0-50.
Unread 31-05-2008, 21:53
Are you pulling pins 2&3 high? Are you sure your pwm timing is correct? Are you following these instructions for calibration? (Not trying to second-guess you, but it's easy to miss some small things )
Unread 31-05-2008, 22:27
FRC #1047
We are connecting pins 1, 2, and 3 to +5v. Pins 6 and 9 are wired together and are connected to ground. Pin 4 is connected to the white pwm wire.
And yes, we are following those instructions.
Basically, we point the compass north, connect and disconnect pin 6 (calibrate) to ground (pin 9, 0v). Then we repeat for the other three directions.
Unread 31-05-2008, 22:41
FRC #1047
Hey guys! We got it to work!
Thanks for your input. It was a stupid mistake on our part.
Unread 23-06-2008, 21:39
westaust55 westaust55 is offline
westaust55 is an unknown quantity at this point
Question Re: Calibrating Devantech cmps03
Hello eagleslg,
I am having seemingly similar problems with a Devantch CMPS03 compass module.
Initially it was working and headings were accurate without needing to calibrate.
I disconnected the CMPS03 while I worked on some other hardware but when I returned to using the CMPS03 I found that the readings returned via the i2c bus are inaccurate.
The readings in (in 2-byte mode) no longer cover the full range from 0 to 3599 but vary from around 600 to 2700 varying gradually up and down in two cycles for a single 360 degree turn.
The values I am getting are as follows (rounded a bit):
compass...1-byte 2-byte
direction...value...value
N............060.....0850
NE..........191.....2700
E…........182.....2560
SE..........171.....2410
SES........085.....1200
S….........087.....1230
SW........092.....1300
W…......073.....1020
WNW.......056.....0788
NW........060.....0850
I am therefore very interested in what you did/found that finally resulted in your compass working correctly as I may have the same mistake/problem.
Devantech CMPS03 compass sensor eagleslg Programming 1 24-05-2008 22:00
Deventeh Digatal - CMPS03 - Robot Compass Module kE7JLM Programming 5 08-11-2007 19:08
Programming a Devantech Magnetic Compass - CMPS03 kE7JLM Programming 7 28-09-2007 08:23
calibrating a cmucam2 muy dificil Programming 2 19-09-2005 12:46
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
