Go to Post Hopefully LMFAO will cross paths with FRC71. They've been shufflin' since 2002. - Taylor [more]
Unread 02-06-2008, 19:41
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Backlash
How much backlash is recommended for gears? I am using AM gears (20 dp, 14.5 pa) and we have the option of cutting the side plates on either an old mill or a waterjet. The mill is by no means state of the art and I would guess that the tolerance is .005". The waterjet tolerance as listed on their website says .005" but our mentor assures me that they can get at least .003" if not much better.
How much backlash would you recommend between two gears? I was thinking .002" but am not really sure if that will be enough.
Also, what are some good places to get hole reamers for .005" under 7/8" and 9/8"? I am planning on having the waterjet cut a smaller hole than needed for the bearing and then pocketing that hole with a reamer so I can press fit an unflanged bearing in there.
thanks, Vivek
EDIT: err... It seems that reamers are meant to go all the way through the hole. What is the best way to make a hole like that? I am planning on using .25" aluminum and leaving a lip of .13-.15" for the bearing to sit against. Gimme a break, I'm still a n00b.
"we don't build robots, we build people"
Unread 02-06-2008, 19:53
AdamHeard's Avatar
Lead Mentor
Re: Backlash
thanks, Vivek
Why not ream all the way through and used flanged bearings?
Unread 02-06-2008, 20:02
vivek16's Avatar
AKA: vivek
Re: Backlash
Well... Flanged bearings are more expensive and we have a bunch of non-flanged ones laying around that work
thanks, Vivek
Unread 02-06-2008, 20:12
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Backlash
thanks, Vivek
Use a through hole and a flanged bearing.
You have a couple other options--all of them involving second operations on a mill. You can use an endmill and interpolate a pocket for the bearing to sit in. If you wanted to use a manual mill, you could use a boring head and bore the diameter down to the flat.
It'd be a heck of a lot easier to use a flanged bearing and a through hole.
as for reams, check McMaster, Enco, KBC Tools, etc. Pretty much any industrial supply/tooling company will have perfectly suitable reams.
You don't want 0.005 under either. More like 0.0005. a 0.005 interference fit is WAY too tight. you want a max of about 0.002 interference. You might be ok going 5 thou under in aluminum, but you could actually deform the bearing in a harder material.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-06-2008, 20:40
vivek16's Avatar
AKA: vivek
Re: Backlash
Where can I get flanged bearings cheap? Is there a place to get them in bulk for a reasonable price? I need 3/8 and 1/2 ID
I would rather not do complicated milling after the initial cutting.
It does seem a lot easier just to do flanged bearings. I guess the low-on-funds-ometer is going off again
thanks, Vivek
EDIT: Also, what kind of reamer? Flute style, length, etc.
Unread 02-06-2008, 20:58
Cory's Avatar
AKA: Cory McBride
Re: Backlash
thanks, Vivek
I'm not sure where the cheapest place to get bearings online is. We get them from a local place.
You just want a straight flute chucking reamer. HSS is fine. No need for carbide.
2001-2004: Team 100
Unread 02-06-2008, 21:02
vivek16's Avatar
AKA: vivek
Re: Backlash
Do I NEED bearings like AM uses or are cheaper ones from the local hardware store fine?
thanks, Vivek
Unread 02-06-2008, 21:14
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Backlash
Honestly the best place I have found to buy bearings is on ebay. The store is VXB wholesale I believe and they have very cheap prices compared to most places.
Mentor 2415
Unread 02-06-2008, 23:46
vivek16's Avatar
AKA: vivek
Re: Backlash
I might just stick with the local hardware store's bearings since they are cheaper. With the run time of a FIRST bot I doubt there will be problems. It is not really a high load situation anyways.
Anyhow, I never did get an answer on how much backlash to put in. I was thinking like .01"? The gear teeth are .1" long and the machine we are using to cut the plates will have .003" tolerance at worst.
thanks, Vivek
Unread 02-06-2008, 23:49
AKA: Sean
Re: Backlash
It is ok to put in none and then just run them in. At least I'm pretty sure it's ok. It is not the "best" method but it accomplishes the same goal and you don't have to worry about to much backlash and power loss.
Mentor 2415
Unread 03-06-2008, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Backlash
I would speculate that you want your center to center distance increased by at least the amount of tolerance of your machine to ensure your gears do not bind. If your machine can only hold .003, I'd say either look for a better machine, or increase your center to center distance .005 over nominal. I'd be weary of going with any more than that though.
For the bearing fit in aluminum, you certainly don't want any more than .001, with something in the range of .0005 being optimal. More than probably .0015 and you'll start to excessively load and potentially even damage the bearing. There are formulas to calculate this, but this is a basic rule of thumb based on experience.
Make sure you use precision ground ABEC rated bearings. If you don't, you'll certainly have problems. Unground and/or non-precision bearings are not rated for anywhere near the speeds, loads, or tolerances of precision ones, by a factor of up to several-fold. I too would recommend through holes and flanged bearings. The most common bearings to use in FRC gearboxes are FR8ZZ and FR6ZZ. These can be obtained from a variety of sources, including Small Parts at about $4 each, under part numbers BRF-06 and BRF-08. There are also cheaper sources. Check local suppliers.
Unread 03-06-2008, 00:15
vivek16's Avatar
AKA: vivek
Re: Backlash
yeah, our machine does atleast .003" (better from what our mentor tells me). We are trying out a waterjet from our sponsors for the first time. They list the tolerance as .005" on their website but my mentor assures me that they can do much better than .003". I made my previous designs for .002" of backlash but it is no big deal to change.
Ok, I will look into flanged bearings. They certainly would make life a lot easier. (Come to think of it, I have half the bearings I need from a toughbox I [slash]demolished[/slash] err... modified )
thanks, Vivek
Unread 03-06-2008, 09:00
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Backlash
If you really want to learn what the right demensions are use a machine design book (norton or shigley) or you can buy an old machinist Handbook. Since you are using spur gears any old addition should have the right info.
As far as tolerance goes, almost any mill that has functional lock on it can hold a tolerance tighter than 0.005 learn how to work against slop and practice.
That being said our team made AL side-plates for an AndyMark gearbox. It took two tries. The first shot I merely explained what to do with the students. They made a couple big set-up errors and the plates wouldn't work. I worked closely with them to make the second set and it worked out better.
Rule of thumb on press fits 0.001" per 1" diameter. This has almost always worked for me in the past. Gearboxes are a good test of skill. They hate being too tight and will destroy themselves if too loose.
Unread 03-06-2008, 18:49
vivek16's Avatar
AKA: vivek
Re: Backlash
I hope to learn more about machining over the summer. Our mechanical team knows how to run the mills but to different extents (and we use a digital readout that holds .0005" of tolerance, although not sure how accurate it is).
I will probably switch to using those flanged bearings.
I am using hex key turned down at the ends for all of my shafts and was wondering how good of an idea it is to turn down hex shaft like that. I would think that all those edges banging against the bit can't be good for it (although if I came in from the side that would be solved. This is what I have done before but the AM hex shafts already had an end turned down onto them.).
thanks,
-Vivek
EDIT: Is an arbor press absolutely necessary for press fit bearings? Could the same effect be achieved without too much trouble with a vice or some blocks of wood and a hammer? I am not against getting one, it seems like they would be quite useful. It is just that we can't really afford luxuries right now .
Unread 03-06-2008, 20:03
Re: Backlash
A suitable vice, a couple pairs of hands and eyes, and some aluminum plates can make a suitable press.
Turning hex shaft into round is common and acceptable. I've done it many times without issue. Just feed slowly.
window motor backlash nic_radford Motors 15 14-02-2004 19:06
