Go to Post FRC isn't all of FIRST. - Rich Kressly [more]
Unread 02-06-2008, 21:00
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
pic: 2009 robot idea
Unread 02-06-2008, 21:02
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Re: pic: 2009 robot idea
nice. you integrated the super shifter into the chassis very well!
how are you running / tensioning your chain?
Unread 02-06-2008, 21:07
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
That looks very similar to our drivetrain this year with a few exceptions, the most notable being ours was a single speed. Some suggestions I have for you. The outer wheels look like they have bearings in the frame. You dont need the bearings as the kit wheels have bearings in them. You can use a 1/2" round standoff that is bolted in place as an axle and it will serve to strengthen the frame. Also you can have the axles on the end slide horizontally in slots to tension the chain. Another thing would be to not have the 80-20 on the ends run into the standoffs. It will require very long bolts which equal more weight. Finally it is ok to use 80-20 if you really want to but using simple 1" box tubing is much lighter and if welded will likely be stronger as well.
Overall though, it is an excellent design and you should look into building it this summer to work out some of the kinks.
Mentor 2415
Unread 02-06-2008, 21:17
Joining the 900 Meme Team
FRC #0079
Maybe use the 1 inch box tubing for the bottom structure and only have the 80-20 on the top as a mounting surface.
Oh! very nice job, it looks good.
Unread 02-06-2008, 21:20
AKA: Sean
I actually really like that idea. It would be the best of both worlds. Really the only reason to use 80-20 is because it is easy to build with with not much planning. It is really to heavy and not strong enough for the weight for much else.
Mentor 2415
Unread 02-06-2008, 22:06
Billfred's Avatar
Billfred Billfred is offline
I'm all for 80/20 in the right situation. The best use of it on a drive system I've seen came from my alma mater of 1293 in 2007. Consider:
http://flickr.com/photos/billfred/1337894883/
The two bolts centered vertically with the 1293 are 1/4"-20 bolts holding each drive pod to the center rails, which appear in this photo to be 1515. Heavy, yes, but it's a pretty short length. The 1515 goes straight through to the outer plate on both pods, tying it all together (and providing pretty awesome nice mounting options for a mechanism to boot).
They haven't had any issues with that aspect of the robot to my knowledge, but I also changed teams right before that season. Someone who was active with D5 that year may be able to tell you more.
Unread 02-06-2008, 22:35
Alumni
thanks for the suggestions. just so you know, the connection between the standoffs and the 8020 pieces was not to be a really long bolt, just a 1.25" long coupler bolt. and im not sure how much our team will be able to change in just one year. in prior years, we have used only 8020 for our entire frame, so anything else would be a major improvement. and to tension the chains, i thought to have some sort of lever arm coming off of the center of the "X" in the side panels, which would connect to a roller which would connect to a spring. but this could be overly complicated. or something like this: http://www.chiefdelphi.com/forums/sh...hain+tensioner
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 02-06-2008, 23:01
AKA: Sean
We did the slots that the axle slides in and then is locked inplace by tightening bolts on each side. This method works extremely well and does not add any weight. I would definitely recommend it over adding an idler that slides and is locked in place like the picture you posted. We used #25 chain and we never had a single problem with our drivetrain the entire season.
Mentor 2415
Unread 03-06-2008, 12:36
Skifanatic's Avatar
Skifanatic Skifanatic is offline
AKA: Matt
FRC #0348 (NHS Robotics)
Skifanatic is an unknown quantity at this point
Send a message via AIM to Skifanatic
Exclamation Re: pic: 2009 robot idea
Looks a lot like 25's drive train but they run it with gears instead of a chain.
-2008 National FINALISTS
-2008 Curie Division CHAMPS
-2008 NYC regional FINALISTS
Unread 03-06-2008, 17:58
Alumni
okay, so i have been further adding features, trying to figure out how to tension the chains. im not too comfortable with moving the wheels in sliding shafts, so i added a bar of sorts to tension the chain.
the lines represent the chain, and the circles represent sprockets and tensioners. the small circles, the ones that appear to be in the slots, are composed of two tubes, the outer being of HDPE, and the inner of polyethylene. the intent was that a bolt would run through these two tubes, and would be able to slide up and down the slot, in order to tension the chains.
Pace Nalbone
Unread 03-06-2008, 18:00
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
You want to shoot for around 120 degrees of chain wrap as a minimum and I think with your current run, you will see major slippage problems with you center axle.
Try moving your tensioners inward or split it into two separate chain runs.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 03-06-2008, 18:14
Alumni
yeah, i guess i didnt make that clear enough, there would be a separate chain going in each direction
Pace Nalbone
Unread 03-06-2008, 18:24
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
this is the classic thread of one infected with the FIRST bug. i love it!
Unread 03-06-2008, 18:25
If that's one chain run, then I want to know how he got a spiral chain wrap.
It's two, with about 180 degrees for each chain and sprocket.
Unread 03-06-2008, 18:30
AndyB's Avatar
AKA: Andy Burchardt
Oh, sorry. Looks good then. I know you designed this to fit the supershifter gearbox, but it might be easier to make if you used 4" tall sides instead of 5".
With 5" sides, you would need to order plate and cut it to length and width.
With 4" sides, you can just purchase 4"x3/16" Extruded Flat Bar and cut it to length.
I guess if your gonna CNC or waterjet them anyways, it isn't that big of a deal, but I'm pretty sure flat bar is cheaper than plate anyways. (I can not find 5"x3/16" extrusion anywhere).
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
pic: 2009 Distribution Block Billfred FRC Control System 16 22-04-2008 17:16
Idea to elevate robot. Gboehm Pneumatics 4 14-01-2007 15:15
Real cool Robot Idea Marcel Rules/Strategy 17 27-02-2006 20:21
Robot competition business idea Swampdude General Forum 6 16-03-2005 16:05
