Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 04-06-2008, 00:39
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Coolest thing on your bot??
What was the coolest thing on your bot this year. For us it was the latex tubing keeping our arm from coming out of it's footprint and the two stage chassis.
R.C.
MadTown Robotics Team 1323
Unread 04-06-2008, 01:23
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Coolest thing on your bot??
Tough call, but I personally like the freaky chain path that was devised by our chassis team this year. It only fell off once, early in the first of our two regionals, but afterwards I think the team got a good idea of how tight to make the chains so that it works.
Unread 04-06-2008, 06:30
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
I can't pick one, but I would have to say our switch to change Hybrid modes. We set it to knock the trackball down w/ robocoach help, do laps, or do a little of both. We mostly did the first one. We had flippers to had flippers to help herd the ball around (AKA shin busters). Then we used car epoxy to hold the frame together and it worked GREAT.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 04-06-2008, 06:32
Billfred's Avatar
Billfred Billfred is offline
I loved our drivetrain this year (granted, there wasn't much else to the robot), but my favorite thing about Speedy Debris is the electrical panel. After a bad connection at the distribution block cost us the quarterfinal round at Palmetto in 2007 (and, admittedly, just not liking how we wired Uppercut), we resolved to step our game up for 2008. The new panel has far shorter wire runs, sits lower, is more compact, and is easier to troubleshoot. Oh, and it's not on a part of the robot that'll come loose and start flapping around.
Unread 04-06-2008, 10:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The final revision of our paws mechanism. It encircled the 300 degrees of the ball, got 2-3 hurdles/match at its peak in Atlanta (needed more practice tbh), and I didn't see anything like at the competitions I went to. Oh yea, and the purple on them helped the elegant aesthetics of the bot too.
GitHub
Unread 04-06-2008, 10:15
ttldomination's Avatar
Sunny
Hm...I would have to say our pool noodles. Knocked the balls down 100% of the times. And, to keep them down, we had them bent forward, under our forks, and so when the forks fell down, then our pool noodles went up.
Or it could be the picture of Dean Kamen we put on our pool noodles...I dunno..you pick.
1648: 2013-2014
5283: 2015
Unread 04-06-2008, 10:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Pictures, please!
Unread 04-06-2008, 11:30
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The coolest thing on our robot was our elevation system coupled with our aquesition it enabled Xtender to be one of the top offensive robots for 2008.
Unread 04-06-2008, 15:26
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
In my opinion, the coolest thing on 1511's bot was our bumpers! They were made out of recycled team pants. We had a problem buying our supply of red camo fabric so we got permission to cut up our old cargo pants and use the fabric. Our seamstress extraordinaire pieced them together (reinforced seams and all) and then recut the fabric for the bumpers!
Here is Shelley and her pile of pants!
http://rollingthunder.smugmug.com/ga...674_oKJtS-A-LB
and our robot with its bumpers! http://rollingthunder.smugmug.com/ga...721_DeMSx-A-LB
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 04-06-2008, 15:37
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
http://www.rutherfordcontrols.com/pr...D=104&zone=can
Two big honkin' Electro-magnets!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 04-06-2008, 16:27
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Probablly the coolest thing in this year's robot is the robot functions. It actually THROWS the ball like a "over-the-head pass" in soccer, instead of pushing or rolling the ball over the overpass. and it's not a shooter.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 04-06-2008, 16:36
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
The use of Juggling rings as our gripper.
Unread 04-06-2008, 19:10
tanmaker
Posts: n/a
Our coolest thing was definitely our independent suspensions. We only did this because we used mecanum wheels this year. Each suspension was extremely easy to detach which made quick repairs a breeze. It really helped when I decided to crash our robot into the block at the end of the lane dividing wall, as shown in picture 2. These suspensions also helped us win the Rockwell award.
ID:	6684  Click image for larger version
Unread 04-06-2008, 19:47
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Our upside down rear bumper.
And our cast aluminum roller claw wheels cast in the shop's foundry using the accumulated scrap from team machining mistakes - they live on to serve a useful purpose. Huzzah.
Unread 04-06-2008, 19:50
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
I remember seeing that coaching 195 that match.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Coolest 'Bot Carts Rick TYler General Forum 83 11-04-2013 22:55
What's The Coolest Thing A Team Can Give Out? Joe Matt General Forum 496 03-04-2008 10:22
The coolest thing in the world! KenWittlief General Forum 23 21-02-2004 02:20
Coolest antweight bot!! Greg Perkins Televised Robotics 5 30-09-2002 17:43
Coolest thing I've seen Deej General Forum 5 17-03-2002 20:54
