Go to Post A link to BoardGameGeek in a FRC blog post... My worlds are colliding, and it's great! - rwodonnell [more]
Unread 05-06-2008, 21:02
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Re: 2009 Control System Feature Wishlist
I don't think there will be much of a problem with the webcam, even if the camera doesn't send info to the cRIO as quickly as it can. Even if the output stream only updates at 8 fps, it should serve its purpose rather well (unless you're doing something really complex with it that requires a faster refresh rate). I don't think it will be a serious issue unless you're doing something really complex.
I am probably not the best person to ask about this, but it's just my thoughts on the matter.
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
2009 Championships Macdaddy549 Rumor Mill 80 02-04-2008 16:22
Vex Wishlist? Donut FIRST Tech Challenge 22 21-04-2006 14:27
2009 Trans-Am? Matt Attallah Chit-Chat 12 01-04-2006 01:08
Button wishlist 2004 natonal's Tytus Gerrish Championship Event 19 16-04-2004 00:53
Wishlist - longer trial period for 3DS MAx Kevin Thorp 3D Animation and Competition 27 06-10-2003 21:47
