Go to Post Isn't that the connector used on the F.L.U.X. Capacitor? - Ed Sparks [more]
Unread 05-06-2008, 22:43
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Get Resistance from Analog In?
Originally Posted by Don Rotolo View Post
Another way (if the range of unknown resistance is very high, or completely unknown) is to create a constant current source and measure the voltage across the resistor - V=R/I, and if I is known and V is measured (make sure it doesn't exceed the analog input range, 5 volts on a 2008 RC) you can calculate R.
Hope that gets you started...
Don
V = IR
Doesn't work the other way around, unfortunately.
With my limited knowledge of physics, I can say that one way to do this might be to connect the two outer terminals of a potentiometer to +5v and G, then connect the wiper to the sense pin of the RC. At one end of the pot, the sense pin would be at a 5v potential difference from ground, and at the other, a 0v potential difference. Definitely use a pot of significant resistance, though, or you'll draw too much current and break something. Find the max current draw from the RC, take a small fraction of that, plug it and 5v into Ohm's law and solve for R.
get distance from cmucam ModMan24 Programming 14 29-10-2010 17:51
Selecting bits from an analog input Spencer E. Programming 2 13-01-2008 09:06
C code to get information from CMUcam2 lrantisi Programming 5 20-03-2007 18:16
Programming Analog Input from 2004 Controller Danny Diaz Programming 8 30-01-2007 22:44
Resistance to Analog Input Value. Josh Hambright Electrical 12 15-04-2003 16:12
