Go to Post I can't believe it someone is talking about next years game rationally! - jamie_1930 [more]
Unread 06-06-2008, 09:47
Happy Birthday! simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Re: Get Resistance from Analog In?
That is exactly how you wire it. If you are using Kevin's code you type in Get_ADC_Result(CHANNEL) =. Channel must be from 1-16 depending on which port you plug it into. It returns in 10 bit resolution so if you are saving it to a byte, do Get_ADC_Result(CHANNEL)/4. If you want to make it slightly faster you can use >>2 instead of /4.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
get distance from cmucam ModMan24 Programming 14 29-10-2010 17:51
Selecting bits from an analog input Spencer E. Programming 2 13-01-2008 09:06
C code to get information from CMUcam2 lrantisi Programming 5 20-03-2007 18:16
Programming Analog Input from 2004 Controller Danny Diaz Programming 8 30-01-2007 22:44
Resistance to Analog Input Value. Josh Hambright Electrical 12 15-04-2003 16:12
