Go to Post Be the change you want to see. - staplemonx [more]
Unread 10-06-2008, 11:24
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
pic: West Coast Altered
Unread 10-06-2008, 11:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: West Coast Altered
The way the 1x1 tubes go all the way through the chassis is exactly what 696 did this year. Very strong, minimizes warping during welding. Worked pretty well.
Unread 10-06-2008, 12:15
REVving up for a new season
FRC #2848 (All-sparks)
is there a pin or some kind of retaining device on the inside of the chassis rails to keep the frame from squishing and becoming narrower after a side impact?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-06-2008, 12:20
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I don't think I'd want to build a robot with that many quick releases in the drivetrain, but from what I've seen at FIRST competitions just about anything will work! Very clever idea.
Which part of the frame do you plan to mount the mechanisms to?
Unread 10-06-2008, 14:06
CraigHickman
Posts: n/a
Nice! Looks cool!
I also like your gearbox design....
Unread 11-06-2008, 14:50
Fidgetting
There is a retaining feature on the inside of the frame. The lexan on the top and botton of the cross supports would be pot riveted to the box beam keeping the side pieces from moving inward.
Any manipulators or other mehcanism would mount to the black supports because the side would be able to come off. In terms of the gearbox, hey why improve on something that aint broke. Its only partially custom (The side plates would be custom) but still sleek and easy to replace if broken. Of course unlike your design it isn't a shifting transmition.
Unread 11-06-2008, 15:02
NickE's Avatar
NickE NickE is offline
_
To save a bit of weight, you could probably go with smaller sprockets.
Are you using 25 or 35 chain?
Also, what is the material for the gearbox sideplates?
254 typically uses Delrin, as it is much lighter than aluminum and strong enough for this application
Finally, when looking at your picture, there are grooves cut out in the front of the side tubing.
Am i correct in thinking that you will be putting another black crossbar in the front?
Unread 11-06-2008, 15:04
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Maverick is fun
Unread 11-06-2008, 15:32
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Is this a challenge??
Seriously, looks good. very innovative way to attach the side rails. I'm gonna have to steal that idea about that crossbeam going though the entire rail. I like it.
Unread 11-06-2008, 15:47
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What benefit does it provide that you don't have now?
Passing the cross members through the side rails makes the design more complicated to manufacture and absorbs impacts as shear against the pin instead of compression of the tubing.
--Madison--
...down at the Ozdust!
Unread 11-06-2008, 15:56
Spark The Ancient
I was assuming that the cross beams were welded in the hole. assuming the weld has proper penetration, the crossbeams would both be able to sustain compression loads just as well, as well as supporting loads from the front of the chassis without shearing the weld. I think we're already going to have to machine the 1x2 rails, what is one more op?
Unread 11-06-2008, 15:58
Madison's Avatar
FRC #0488 (Xbot)
I believe Alex's intent was that the cross members be pinned in place, making the side rails removable. Welding them would place them into compression and be fine -- but if you're going to weld them, why bother machining a hole into the side rail at all?
Again, though, it's all a matter of weighing the good against the bad. Machining work is resource and time intensive, so we prioritize other solutions. For some folks, it's a way of ensuring quality workmanship and isn't an undue burden.
--Madison--
Unread 11-06-2008, 19:46
Fidgetting
The sprockets are for #25 chain. The reason that they are so large is because I was originally planning on using cross braces that are as tall as the sides and the sprockets would need the chain to clear them. I simply haven't been motivated to change them.
The side plates are currently aluminum but theres no reason they need to stay that way. The grooves in the front to so that the sides are identical and can be switched without needing to have one of each. The actual would probably use another to mount bumpers.
Unread 11-06-2008, 20:03
NickE's Avatar
_
As a compromise, you could always make the front and back crossbraces the full height of the sidebeams, and use the half size ones for the in-between crossbraces.
This would allow you to keep the sprockets small and to still retain more strength than having all half size crossbeams.
Unread 12-06-2008, 01:01
CraigHickman
Posts: n/a
It should be! CAD off! Gogogogogogo!
West Coast Post-Season Scrimmage rsilverstein Off-Season Events 12 27-03-2007 23:52
pic: West Coast Collaborationz and Team 254 Present phrozen solyd Robot Showcase 22 28-02-2005 01:31
anyone in california/ west coast Cappy697 Chit-Chat 19 06-02-2004 13:56
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
Types Robots of the WEst Coast SpaceOsc Rumor Mill 5 27-01-2003 23:38
