Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
View Poll Results: What do the attached numbers say?
111 29 29.90%
777 68 70.10%
Voters: 97. You may not vote on this poll
Unread 10-06-2008, 11:46
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Settle a Debate...
What do the numbers in the attached picture say?
Help settle a debate.
Unread 10-06-2008, 11:55
artdutra04's Avatar
VEX Robotics Engineer
Re: Settle a Debate...
It's 777.
If they wanted to make those into ones, they should have put the flat line on the bottom of the 1.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-06-2008, 11:57
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Originally Posted by artdutra04 View Post
It's 777.
777 .. flat line or no flat line, the line at the top seems too big for a 1, proportionally.
Brandon Martus
e-mail
Unread 10-06-2008, 12:01
Onward through the fog.
I looked at the thumbnail before reading your question.
777
Immediately.
Edit: Ok, if you colored them to be wild tie-dye colors, the visual would project 111 pretty easily, I think.
Because the stem is more straight rather than slanted, I can see why you would think them to be 111 and say they are, using that font, but the initial reaction is still 777 in green.
~ Helen Keller
(1880-1968)
Last edited by JaneYoung : 10-06-2008 at 12:09. Reason: edit - not that it makes any sense
Unread 10-06-2008, 12:02
Since it's a given that they're numbers, I have to say 777. I can give two arguments in favor of that and against "111" if you want me to.
(My first impression, however, was three of the Hebrew letter lamed.)
Unread 10-06-2008, 12:35
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I dunno, the top parts of the numbers are just not level enough to make them sevens. I say Wildstang all the way.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 10-06-2008, 13:27
Best Available Data
FRC #1778 (Chill Out!)
111.
They're not quite 7ish enough to be sevens. If the long stroke was just slightly more slanted, or if the short stroke was slightly longer, then I'd say seven. I think the intent was a 1, just they came out slightly seveny.
Unread 10-06-2008, 13:37
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Definitely, 111.
Look at how the top line is slanted down. You don't get that on a 7 just look at the numbers that I type. That slant appears in the 1 but the 7 is clearly flat acrossed the top. Just a thought, but why not ask the person who put up the sign?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 10-06-2008, 13:42
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
They are "1"s with 7 envy.
AB
Unread 10-06-2008, 13:55
It looks like the numbers are actually slightly tilted left in the picture, which would make them sevens.
Or maybe it's a combination of ones and sevens. Interesting binary, if that's the case...
Unread 10-06-2008, 13:59
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Now call me a redneck, but some local sprint cars in town have numbers similar to that, the car number is 11, so I will say 111.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 10-06-2008, 16:00
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
It could go either way... but they look more like 7s.
If they had bottom lines (or were tie-dyed), they would definitely be 1s.
If they had more slanted stems, they would definitely be 7s.
That is just a confusing font.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 10-06-2008, 16:45
Bob Steele's Avatar
AKA: Bob Steele
Perhaps now ... one can see why we were taught in Europe to write 7's and 1's differently...
Those are definitely European 1's
7's have a mark halfway down....
R
Unread 10-06-2008, 17:54
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Even though I voted for 777....
Perhaps there is a wayward "4" to the right of the pic somewhere and the 1's were all running to meet it? That would explain the lean to the right and the "hair" flowing straight back behind them to the left.
Unread 10-06-2008, 18:30
Billfred's Avatar
Billfred Billfred is offline
Those are sevens--the weight of the upper part is just too much for that to be a one. (And besides, I've seen those numbers on some cars. The ones look different.)
Robotics Class Debate George A. Chit-Chat 21 10-05-2004 20:05
