Go to Post Scientists ask Why, Engineers ask Why not. - Rohith Surampudi [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 10-06-2008, 13:50
KHall KHall is offline
KHall - 2171 Crown Point IN
FRC #2171 (RoboDogs)
KHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud of
LabView FRC Toolkit code level issue
Hello,
As I was working on the second tutorial, I came across an issue inside the FRC toolkit. The subVi called 'Packet Reader.vi' was apparently created with LabView 8.5. The all the other subVis in the FRC kit appear to be compatible with version 8.2. The tutorial also specifies using LabView 8.2. The screen dumps in the jpg below should help you understand what's happening.
I tried downloading the older version of the toolkit, but apparently that link is not longer available.
So, could someone please post a version of the Packet Reader.vi at level 8.2?
Oh, and as long as I'm at it -- any chance we could get the Ultrasonic sensor added to the FRC toolkit? If not, can you please explain a work-around? We do use those sensors and I didn't see any way to read the contents of a register directly from the FRC controller into the LabView simulation during the tutorials.
Thanks much,
KHall
Name:	labview rev issue.jpg
Unread 11-06-2008, 02:23
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: LabView FRC Toolkit code level issue
I am sorry, but the Simulation and Modeling Toolkit is no longer being supported. All FRC teams were provided LabVIEW 8.5 in the 2008 FRC KOP, and the updates to the packet reader were made in 2008 and were done in LabVIEW 8.5 - please use the updated version of LabVIEW if you are going to continue to use the toolkit, there were significant stability enhancements made to LabVIEW 8.5 and if you have any problems/questions with using LabVIEW 8.5 we will be better equipped to support you.
National Instruments will be introducing a new software package for the 2009 FRC season, and all of our efforts will be put into supporting and maintaining that software package.
Thank you for your interest.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 11-06-2008, 10:40
Thank-you Danny.
Please let me repeat my request. I'm asking if someone could please post the file 'Packet Reader.vi' in version 8.2.
The version 8.5 file can be saved as a version 8.2 by opening it and using the pull down menus to File>Save for Previous Version... and select 8.2.
The path to the file is: /FRC/user.lib/_frc/Dashboard Provider/Packet Reader.vi
Danny, I respect your position as being a good corporate spokesman. But I was really looking more for some GP from one of the other FRC teams, not support from the NI corporation.
Thanks all,
KHall
Interrupt issue with new code EHaskins Programming 6 05-01-2008 00:27
FRC 48: Transmission Issue A_Reed Technical Discussion 2 18-02-2007 15:52
Question about using labView in FRC itsme LabView and Data Acquisition 7 19-01-2007 15:22
Serial Communication Problems with LabVIEW FRC Toolkit Jon236 LabView and Data Acquisition 1 28-12-2006 11:57
FRC Championships in the latest ROBOT magazine issue skimoose Chit-Chat 12 07-08-2006 22:28
