Re: pic: West Coast Altered
To save a bit of weight, you could probably go with smaller sprockets.
Are you using 25 or 35 chain? Also, what is the material for the gearbox sideplates? 254 typically uses Delrin, as it is much lighter than aluminum and strong enough for this application Finally, when looking at your picture, there are grooves cut out in the front of the side tubing. Am i correct in thinking that you will be putting another black crossbar in the front? |
Maverick is fun
Is this a challenge??
Seriously, looks good. very innovative way to attach the side rails. I'm gonna have to steal that idea about that crossbeam going though the entire rail. I like it. |
Passing the cross members through the side rails makes the design more complicated to manufacture and absorbs impacts as shear against the pin instead of compression of the tubing. |
I was assuming that the cross beams were welded in the hole. assuming the weld has proper penetration, the crossbeams would both be able to sustain compression loads just as well, as well as supporting loads from the front of the chassis without shearing the weld. I think we're already going to have to machine the 1x2 rails, what is one more op?
Again, though, it's all a matter of weighing the good against the bad. Machining work is resource and time intensive, so we prioritize other solutions. For some folks, it's a way of ensuring quality workmanship and isn't an undue burden. |
#7
It should be! CAD off! Gogogogogogo!
#8
i wish, my computer is down atm and it will be a few days before i can get back to SW, luckily all my CAD files were backed up! expect to see some cool stuff soon.
#9
hehehehe, when, where and what are we CAD'ing?
The braces weren't going to be full height for strength reasons, They would have been full height because the original idea was for the frame to be completely pop riveted and all the braces would need to be the same height for this. oh, and yes Maverick is fun. Last edited by Alex.Norton : 13-06-2008 at 01:05. |
#10
The side plates are currently aluminum but theres no reason they need to stay that way. The grooves in the front to so that the sides are identical and can be switched without needing to have one of each. The actual would probably use another to mount bumpers. |
#11
This would allow you to keep the sprockets small and to still retain more strength than having all half size crossbeams. |
| West Coast Post-Season Scrimmage | rsilverstein | Off-Season Events | 12 | 27-03-2007 23:52 |
| pic: West Coast Collaborationz and Team 254 Present | phrozen solyd | Robot Showcase | 22 | 28-02-2005 01:31 |
| anyone in california/ west coast | Cappy697 | Chit-Chat | 19 | 06-02-2004 13:56 |
| East Coast, West Coast, and Midwest FIRST | Aaron Lussier | General Forum | 52 | 04-08-2003 01:52 |
| Types Robots of the WEst Coast | SpaceOsc | Rumor Mill | 5 | 27-01-2003 23:38 |
