Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Unread 12-06-2008, 03:58
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Radio Channels
Does anyone know how to get 8 O/I's and R/C's working together with no interference?
I am already aware of the 6 channels you can access by changing the channel dip switches on the O/I... but i need to run 8 of them not 6... Is this possible?
Unread 12-06-2008, 11:29
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Radio Channels
I don't know of a way to do 8 channels. I called them once to ask and was also aware of the 6 channels. (Tried to set this up for the Muncie Pre-Invitational this year.)
Actually if you are getting 6 channels to work together, you are VERY LUCKY. Really there are only 5 channels that will work.
From the manual:
"Note: Do not use Channel 31 and 40 at the same time with the 2007 or newer Radio Modems, interference between these Channels can cause intermittent radio communications."
See PDF page #16
http://www.ifirobotics.com/docs/oi-ref-guide-5-8-07.pdf
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 12-06-2008, 17:55
popo308's Avatar
AKA: Brent
Re: Radio Channels
Originally Posted by Chris_Elston View Post
From the manual:
See PDF page #16
Does anyone know if the 06 radios have this same problem?
Do Channels Matter? irishninja FIRST Tech Challenge 7 10-04-2006 14:54
Switching Channels Fred Agnir Control System 5 20-01-2006 20:54
Selecting alternate radio channels on 2005? Alan Anderson Control System 2 20-01-2005 10:15
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
PO Channels Kyle Fenton Technical Discussion 3 14-08-2001 12:54
