Go to Post Personally, I'm really not jealous of any good team in FIRST. I'm happy for them, and take a page out of their books to see how we can better impact our students in the future. - waialua359 [more]
Unread 11-06-2008, 11:52
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: Madtown Robotics Future Frame Proto 1
Unread 11-06-2008, 11:55
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Madtown Robotics Future Frame Proto 1
It looks good, but I'm worried about cross-support when another bot hits this one on the side. Also, any details?
GitHub
Unread 11-06-2008, 11:56
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Okay I'll bite.
Why?
That's a lot of machining to make something that looks cool, but why spend the machine time and effort on it?
Looks good and all I'm just putting my pragmatic hat on and thinking about resource alllocation.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 11-06-2008, 12:27
run the trap!!!
Team Role: Human Player
I suppose you already know that two of the wheels are missing Are you planing on using omnis in the front?
Secondly I'd be interested to know what kind of motors and transmissions you are using. Those look kind of like the Bosch drill motors that used to come in the kit. Your guess is as good as mine as to what parts we are getting in the kit next year, but I'd venture to guess that we won't be seeing the Boschs again
I'm not sure I'd dismiss this design as requiring too much machining. It really depends on what kind of resources and experience Madtown has. If they have access to a water-jet cutter this shouldn't be too hard to make.
I do think however, that some of the lightening patterns may be weakening the frame too much. When making a truss pattern like that its best if you leave a bit of a radius at each corner. Simply cutting right angles can lead to stress fractures at the joints.
Good job so far!
-Philip J. Fry
Unread 11-06-2008, 12:48
How are you going to maintain it? It looks like if something breaks, you are going to have to reach in through the bottom, and that isn't going to be easy.
Unread 11-06-2008, 13:07
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I was wondering the same thing, it might depend. Are the center wheels dropped?
I like how it says madtown on the top.
Unread 11-06-2008, 17:16
R.C.'s Avatar
The Frame: It is two 4x4 1/8" 6061 Aluminum tubing CNC out for the lettering and pattern. Solidworks says it weighs about 25 pounds with the 4 gearboxes, 4 cims, 4 4x2 wheels and everything else minus the battery. I put it through a three hundred force test and it bends in the middle by a few inches and the front wants to really cave in. The sheet of aluminum can stand about 110-120 pounds of force without really caving in. The back is sheet of carbon fiber and it bolted in. The reason for this is the weight saving and the high impact strength. The reason for this frame is because it's twenty pounds lighter with more stuff added on. Quick and easy assembly.
For the first question: Currently it is held together with a 1/8 CNC bottom sheet of 7075 aluminum. Depending on what we go with: forklift, 4 bar arm or telescopic arm. We will either put two 1x1 aluminum tubing across to support it or put a sheet in the front.
Question 2: The reason for all the machining is that we have started a summer program. Our Vp got a brand new 60,000 dollar CNC Machine. Also our engineers were leaning toward a new frame. Our two stage frame was industructable but really heavy and that affected the building of our hand.
Question 3: Yes were putting omni's in the front, but i am having a real hard time making them. Does anyone have a link or the file for a 4 inch double set omni wheels? Thanks in advance. No they're not bosh drill motor gearboxes, i wish they were. But they are the dewalt drill gearboxes, i forgot to put the color in. We also have access to a waterjet cutter now.
Question 4: Our new cart is designed to be able to work under the robot. We prefer to work under and this year at nationals we managed to pull the supershifters about 10 times. The only way to pull them was to go under. The supershifters were great but the cims and the roll pin kept giving us trouble in between rounds. This setup is better because there are square cut outs in the bottom that allows easy access for the wheels and chain.
Question 5: No the center wheel is not going to be dropped. We talked to the Kil-a-Bytes, 1024 and few other teams that used omni's in the front and did not drop the center wheels and had way better turning. Our turning sucked this year but it helped our robots center of gravity out by a lot because it had that rocker affect.
Thanks Cd for the support and continue giving 1323 ideas to improve this frame.
R.C.
MadTown Robotics Team 1323
Unread 11-06-2008, 21:46
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Perhaps I am misunderstanding your test, but the results are throwing a flag for me. Assuming that was a simulated test, did you get the deflection by looking at the screen display or did it actually give you a number?
Mark
Brick walls are for other people. - Randy Pausch
Unread 11-06-2008, 23:13
R.C.'s Avatar
My bad, too much writing: I meant 150 pounds.
R.C.
Unread 12-06-2008, 06:37
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Personally I dont like the direct connection between the motor and trans to the wheels cause if you get hit hard enough you could bend the drive shaft coming off of the trans. Or am I just seeing it wrong and it's chain/belt driven.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 12-06-2008, 08:41
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
You should look for a stronger way to beef up that frame; especially running along the length of the robot. I would suggest making the ribs along the corners of the box extrusion have at least a .625 or .75 lip.
Also, what kind of CNC machine would this be produced on? If it's just a regular milling machine, you'd honestly be staring at the machine for days to machine those side rails. I've seen even simple triangulation patterns take an hour.
A much better solution would be to reduce the number of pockets in half by using larger, triangular-shaped pockets. This would be harder, better, faster, stronger, and a lot easier to machine. (Time is money during the build season).
(Remember, a 150 pound force on a robot frame would be the equivalent of static loading if the robot were to push against a wall. During impacts, the force skyrockets in short bursts, which could easily exceed the 150 or 300 pound load test and bend your frame.)
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-06-2008, 11:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Another consideration is that all of your cool designs on the machining will not be visible due to bumper.
If it was me I would simplify the trusses to a triangular pattern to speed up machining and make it stronger.
Mentor 2415
Unread 12-06-2008, 13:53
R.C.'s Avatar
It is Chain driven and the machining for this proto will be done over summer as a CNC test and we will make another and i do need to strengthen it up a bit =)
R.C.
Unread 12-06-2008, 16:23
AdamHeard's Avatar
Lead Mentor
Very, very true. If you have taken physics you can do some approximations (they won't be very accurate) of the forces involved if two robots impact. Even though inaccurate, you'll be able to see that some very high forces can be applied in impacts.
Unread 12-06-2008, 17:52
R.C.'s Avatar
Our 2006 robot came back from Nationals and the 80/20 material was all bent up and the bot looked as if it had fallen off a roof top or something
R.C.
pic: MadTown 1323 Robot Mast Shot Robo_Coyote Extra Discussion 7 06-02-2007 21:58
pic: Screenshot of Madtown Robotics Team 1323 Website. Hefner Extra Discussion 1 02-02-2007 21:18
Team 135 proto 1 CarpeDiem Robot Showcase 2 23-01-2006 21:26
pic: Team 121 Arm Proto Rob Extra Discussion 6 20-01-2005 23:01
Question About the Dashboard Proto. burNeD Programming 2 06-04-2004 13:09
