Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 12-06-2008, 17:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Lithium Charging and Balancing Circuit Needed
I'm in need of a small Lithion-Ion or Lithium Polymer charing and balancing circuit. Ideally it would be a PCB without a housing or anything, and less than 3" square and 1/2" thick. But, I'm open to seeing what's out there. It needs to be able to charge a 6S2P lithium battery (at a slow rate).
Unread 12-06-2008, 17:56
AdamHeard's Avatar
Lead Mentor
Re: Lithium Charging and Balancing Circuit Needed
I'm no expert in the area, but based on the charges I have seen/used for my lithium batteries; that size requirement is a little harsh.
Unread 12-06-2008, 18:00
I've been looking for a couple days, but probably not in the correct places. I don't want a hobby charger, I want something designed more for an OEM application. Also, it needs to take DC current as the input.
Unread 12-06-2008, 19:20
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
This post isn't really too much of a help, besides marking off websites that have been checked out. Sparkfun had these two, but they don't have enough spank for the 4400 mAh 22.2V battery you are looking to charge. Sorry :/
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 12-06-2008, 20:02
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I would not ignore RC shops, they often have exactly what you're looking for.
For example, TowerHobbies has this this balancer (up to 6S).
Also, if you buy the LiPo packs there, they usually come with tiny load balancers shrink-wrapped to the cells.
Backup Battery Charging Circuit David55 Electrical 7 25-02-2007 23:37
Back-up battery charging circuit from IFI Don Wright Electrical 19 02-05-2006 20:41
Victor and Spike in same circuit? phillutz Electrical 4 18-02-2005 16:57
Serial Port and Custom Circuit Ryan Meador Programming 40 06-02-2003 11:34
Reference Balancing the Bridge and 2 goals archiver 2001 0 24-06-2002 00:54
