Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 13-06-2008, 16:01
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
FIRST weigh in scales
Does anyone know the brand and model number of the exact scales the inspectors use at FIRST events?
I assume they are a standard off the shelf brand pallet/floor scale by some company but I have never really payed enough attention during inspection. I am looking for a floor/pallet type scale but don't need a huge one with a capacity of 5000 or 10,000 lbs. and would prefer one of about the size used in FIRST inspections with a capacity between 800-1000 lbs and the best accuracy possible. In other words I would rather have a 2' x 2' 1000 lb capacity scale with a 0.1 lb accuracy than a 4' x 4' 10,000lb capacity scale with 1.0+ lb accuracy. My brief internet searches have turned up a lot of the later but few of the former and then I was thinking of the FIRST scales and wonder if they wouldn't be just about right. Any inspectors out there know the brand/model of scales FIRST uses?
Thanks.
Unread 13-06-2008, 16:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: FIRST weigh in scales
I think this picture I took is from a FIRST competition....
($600 for 1000 lb x .1 lb)
http://www.arlynscales.com/Platform-...form-scale.htm
Unread 13-06-2008, 16:46
Perfect! Thanks! That led me to here: http://www.arlynscales.com/Platform-...form-scale.htm which is just what I am looking for and at a price that beats most other places I have seen.
Unread 14-06-2008, 12:48
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
This is the info I got from the Lead Inspector at GLR...
http://www.arlynscales.com/industria...47ef147fec4b55
I am guessing that it was a 500 LBS scale.
320D-36 - 36" x 36" x 1 7/8" 500 lbs x 0.1 lb $899.00
Mark
Brick walls are for other people. - Randy Pausch
Unread 14-06-2008, 18:51
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Team 228 had two scales donated to us in 2004 from BMS; one was a 150 lb scale and the other was a 400 lb scale. The 150 lb has higher precision, but we normally use the 400 lb since we've found that a lot of students like to stand on them to see how much they weigh.
I've found the same models on McMaster: 17295T31 and 17295T39.
They are a lot cheaper than the other models, if you don't mind the +/- 0.2 or +/-0.5 lb increments respectively.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-06-2008, 19:28
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
Speaking of FIRST scales. Our team we about 118lbs in Manchester. At Chesapeake we added about 2-3 pounds of upgrades and fixes. We were wondering how close it was going to be, but to our amazement, when we put the robot on the scale, it weighed a tiny bit less. Anybody have any idea how this could happen?
Unread 14-06-2008, 19:29
Different scales, different floors... It's been said that with several scales, a slightly heavier team would be directed to the "lightest"... Before calibration measures were taken, that is.
How much do you weigh? mta General Forum 3 19-02-2008 12:06
What is your frame weigh? RTTComanche17 General Forum 8 09-01-2008 11:05
We will have portable scales at VCU and Nationals DRH2o Regional Competitions 2 03-02-2007 23:17
What scales to weight robot? chocolateluvrlr General Forum 41 08-04-2005 21:43
weigh ins Collin Fultz Rules/Strategy 8 15-02-2003 10:45
