Go to Post The GDC giveth, the GDC taketh away. Blessed be the name of the GDC. - GaryVoshol [more]
Unread 15-06-2008, 21:12
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Dual C18 Compilers and MPLAB?
I know there has to be someone that has done this as it seems like it could be a common problem.
Here are my needs:
I need MPLAB v7.20 and the C18 Compiler v2.40.
I need MPLAB v8.10 and the C18 Compiler v3.10.
How do I dual install both of these to work.
I'm trying to program VEX robots this week, so I have to use my v7.20 and v2.40 of MPLAB and C18.
I also need to program our FRC robot this week, and we use Kevin's code, and we need MPLAB v8.10 to open the file, and we have been using v3.10 of C18.
Another alternative would be to find VEX code compatible with MPLAB v8.10 and C18 v3.10.
I've tried to install both before, but as anyone can guess, it didn't do so well.
Any help or advice?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 15-06-2008, 22:00
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Dual C18 Compilers and MPLAB?
Here are my needs:
Yes it is possible. This is exactly how I run my laptop. I use version 2.4 for working with my Vex, and version 3.1 for working with FRC. I learned this little trick from Kevin Watson. It is actually a lot easier than you think. It is as simple as installing version 2.4, then renaming the mcc18 folder to mcc18_2.4. I then install mcc18 version 3.1. Now on my laptop MPLab will run with the compiler version 3.1 for use with FRC. What I want to program my Vex, I renamed the mcc18 folder mcc18_3.1, and rename the folder mcc18_2.4 to mcc18. Then my laptop is ready to use MPLab with version 2.4 of the compiler for use with Vex.
That is all there is to it.
I have been using version 8.1 of MPLab for both Vex and FRC. It works quite nicely in this configuration.
Unread 15-06-2008, 22:10
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
I've never heard of that method before, I might have to give that a shot. What I've been doing is running a virtual machine so I have one version of MPLab and the compiler directly on my laptop, and then the other version in a virtual operating system that can run simultaneously with the standard operating system. There are a few programs out there to run virtual machines including, VMWare, Virtual Box, and Microsoft Virtual Machine. That seems to work well for me, especially since for some reason on Vista, IFI loader cannot load anything into the robot so I run a virtual XP and everything loads perfectly.
Unread 15-06-2008, 22:21
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I just have a pair of batch files:
renames mcc18 to mcc18_24 then mcc18_31 to mcc18
renames mcc18 to mcc18_31 then mcc18_24 to mcc18
Eric Haskins KC9JVH
Unread 15-06-2008, 22:57
RyanN's Avatar
RyanN
Sounds good, I haven't tried that exactly. I've tried installing MPLAB v7.2 and 8.1 in two different locations and also same with the C18 compiler, I could get nothing to work right even with the libraries located in MPLAB. I'll have to give this a shot tomorrow.
Also... I wonder if v3.2 of the C18 compiler will work... 3.1 disappeared off the website.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 15-06-2008, 23:23
AKA: Eric Haskins
Why do you want MPLab 7.2 and 8.1? I've been using MPLab 8.x with c18 2.4 and 3.1 without any issues.
Eric Haskins KC9JVH
Unread 15-06-2008, 23:24
RyanN's Avatar
RyanN
I was having issues opening the workspaces. It may be related to the C18 compiler though.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 16-06-2008, 01:09
AKA: Eric Haskins
If I remember correctly, if you open the project(.mcp) it will open fine, but only if you delete the workspace(.mcw) first. The only thing you loose is the window layout you used in 7.x, but whatever you do in 8.x will be saved/loaded correctly in the future.
Eric Haskins KC9JVH
Unread 19-06-2008, 08:46
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
You should be OK if you have them installed in separate directories, and neither install location is added to your path. You'll have to manually specify the tool locations in MPLab, but that should be fine.
Steve Guerrera
-2003 T.R.I.B.E. 237
2004-2008 Nutrons 125
Boston Regional Mentor
MIT Grad Student
New C18 MPLab and IFI Loader? blaxbb Programming 5 06-01-2008 18:25
MPLAB/C18/IFI-utils Licensing Orborde Programming 1 18-12-2007 08:48
MPLab 7.20/C18 2.40 Andy L Programming 2 07-04-2007 20:11
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
