Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 10-06-2008, 21:05
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
Re: Wireless Networks at Competitions
If all the controls are running on 2.4, I would just get a new 802.11n router that can run on the 5.0Ghz band. That should eliminate interference and create a really large coverage area.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 10-06-2008, 23:00
rdlevy1215's Avatar
rdlevy1215 rdlevy1215 is offline
FRC #1676 (Pascack Pi-oneers)
rdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud of
Based on what I heard from NI, they believe that 802.11 A is an "old" technology and not worth using for the robots ... therefore, all you need to do is use A (5.8 Ghz) and there will be no interference issues and no problem
Robert D. Levy
Team 1676, "Pascack Pi-oneers"
http://www.team1676.com/
admin@team1676.com
Unread 11-06-2008, 10:23
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
So the general idea here is that it is unlikely that they will allow wireless networks next year. It's a real shame because that's how a lot of teams are probably going to start doing their scouting.
Now, was wireless networks allowed this year?
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 11-06-2008, 12:49
NickE's Avatar
NickE NickE is offline
_
I believe they were allowed at regionals, but not the championship
Unread 12-06-2008, 03:17
Nibbles Nibbles is offline
Interstellar Hitchhiker
AKA: Austin Wright
FRC #0498 (Cobra Commanders)
Nibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really nice
It depends on the system FIRST/NI goes with. It has been explained in other threads there are three non-overlapping channels (11 total, but some overlap), channel... 1 for example, could be set aside for team use. I don't see this happening as it is too confusing, if non-interference is essential, but it would work. Then again, if non-interference is essential, you shouldn't be using the 2.4Ghz band.
I hope we go with a 5.0Ghz system (I believe 802.11a does and with some configuration, n does too), with a single FIRST-controlled access point that all the control stations plug into (that means 7 wireless broadcasting devices total), and use a small Wifi-Ethernet bridge to use with the robot, which would look very much like the older transmitters. Lots of bandwidth, less interference then having an access point on each robot and 12 broadcasting nodes, simple, one network to connect to, no confusion. Hopefully. I have no clue how this will all be zero configuration. Each robot connects to a authentication-required access point, always called "FRC" or something, and gets an IPv4 address with DHCP, then discovers the driver controller with a service discovery protocol, driver controller pings back, station light stops blinking. Hm, idk how I feel about using WiFi after all :-/
I am also awaiting the return of Sundial, that would mean reserving a channel if not the entire 2.4Ghz spectrum, for team use. On a side note, I hope the field controller is free software along with the robot controller library (right now only the programming library has been mentioned, and it has only been called open source, of which free software is more or less a subset). Maybe I will start a thread on the field controller exclusively.
So, 900Mhz video systems are looking like a good possibility, but could find another use in FRC besides personnel two-way-radios. Dial up modems anyone? Don't worry, the theoretical speed from a 900Mhs two-way-radio is orders faster then telephone.
You could use Light for medium distance communications: http://ronja.twibright.com/
Whichever band of Wi-Fi FIRST uses (2.4Ghz vs 5Ghz), use the other. If the field controller uses a single access point, that means one channel, so you could use a different channel, 1, 6, or 11 depending on what FIRST is not using. Again, this could get confusing, even using a different band entirely, so not even that may be allowed.
The Short answer: Plan on using good ol' Ethernet, but wait and see. Ethernet attached to a plain old router (even a wireless one with WiFi turned off) saves lots of time and hassle anyways, if three extra cables are not too much work for you.
Help standardize match data! Use the XML interchange format. (Specification page)
AAA_awright on Freenode IRC chat. (Join us at ##FRC on chat.freenode.net, or in your browser)
Unread 12-06-2008, 08:59
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I'd say start working on other forms of wireless communication. Scout using Morse Code, hand signals, light flashes (LOST anybody?)... Paper cups and string are cheap too...
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 13-06-2008, 20:52
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
We should create string networks at Nats. Just have miles of string running between the Georgia Dome and the GWCC.
Unread 13-06-2008, 22:21
cooker52's Avatar
Cookie
AKA: Seth Cook
FRC #4272
"Need a query, ask the cup!"
Now that would be fun . Now all we need is a sponsor crazy enough to supply us with the few hundred cups and the couples miles of string.
Unread 16-06-2008, 01:18
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Originally Posted by EHaskins View Post
Personally I don't think that any such restrictions would be practical or even possible to enforce, and if the new control system can't handle some other networks in the same area, then we're going to have some big problems next year, especially with the number of wireless networks growing like they are.
According to Bill Miller, Director of FRC, at the Mentor Q&A during this year's Championship, they would be policing the air waves with some powerful tracking system that would allow identification of a wireless router or something in a team's pit. I'm not exactly sure of the details, but it sounds like it will be enforced.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 16-06-2008, 01:37
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
They may be able to control the networks within the competition venue, but there is no way they could restrict networks in the surounding area. I know that at the Milwakuee regional I was able to detect 5 to 15 non-team networks at any time, depending where I was in the venue.
Even if they did somehow manage to eliminate ALL team networks (which will not happen*) and all of the non-first related networks, they would still have issues with other 2.4ghz devices.
As I said before, if the new system can not handle other devices operating in the same band, then, no matter what rules they put in place, the system should not be used. Especially when the band they're using is so heavily occupied.
* Not all teams read the rules thoroughly. Some people will break the rules without even knowing it.
Eric Haskins KC9JVH
Unread 16-06-2008, 01:52
NickE's Avatar
_
Yes, as you have said, it would be impossible to restrict all 2.4ghz devices. Therefore, instead of b or g, 802.11a should be used as the primary means of wireless communication for the 2009 FRC Control System.
802.11a runs over the 5.0ghz band. This band is much less congested than the 2.4ghz band.
It has 12 non-overlapping channels (compared to 802.11g's 3). Therefore, come time for championships, each field could have its own channel (or even one per alliance per field), reducing almost all network channel interference
Also, there are very few wireless networks that use 802.11a. Therefore, FIRST would have practically no work to do when it comes to wireless network policing, as just about all teams with networks of their own would be using b or g on the 2.4ghz band.
Unread 16-06-2008, 01:55
UndergroundVoid's Avatar
UndergroundVoid UndergroundVoid is offline
System Ready...
AKA: Lynx
UndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the rough
Send a message via AIM to UndergroundVoid
I'm surprised in the no fate it technology and programming here. This is a guess but they might do a lock out system where once a robot is connected and confirms by some code them it will block out all other possible connection attempts. kinda how when you sync up you blue tooth phone to a computer it give you a pass key for confirmation.
As for pit wireless, come on people suck it up and just use a Ethernet cable for programming because:
1. You have nothing to lose.
2. You stay out of trouble in the long run.
3. Your programming should have been completed during build season and only should require tweaking.
4. What internet service are you going to be broadcasting out.
So in the long run people just bring a cable and stop trying to be lazy, we have gotten this far with daisy chains of serial cables, so why not buy a 2 foot Ethernet cable for the pit and a 30 foot for the practice field which together would cost less than 15 dollars.
So the real question is not that is it allowed but do you really need it and why a debate over a nonexistent rule? I get the impression here that people want to do things just because they are lazy but yet fear it since they don't trust the technology and programming.
This goes back it to the old fashion "what if this, what if that" but you will never know till it happens yet you can always dream.
Please people think before writing and consider all the possibilities and outcomes and do some research in the technology in this field you may be surprised on what you may find.
I refuse to go silently into the night by taking the easy way out.
The manual doesn't have all the answers since nobody can plan for everything.
Things can be more simple than you think.
Unread 16-06-2008, 02:14
AKA: Austin Wright
It seems like if it uses electricity, it interferes with the 2.4Ghz range (Alright, maybe not that bad).
You are exactly right, if it is any critical reason, they should be using something else.
This makes me wonder how robots will be controlled in the pits, obviously not with WiFi. The upshot of using IP is that the transport layer is irrelevant, be it Ethernet or WiFi (which borrows quite a bit from Ethernet, such as MAC addresses), IP doesn't care. How you connect to the robot will be interesting, there are two Ethernet ports on the robot controller, one it is very strongly hinted will be used for an Ethernet camera. The other then has to do to the communication mechanism, so maybe the Wi-Fi node or access point has a hub or switch inside it. I'll ponder this a little more.
Couldn't they just enclose all the robots in a Faraday cage and not worry? Actually, covering the field would be impractical, but surrounding the team pits, with two equal size foil walls on each side, connected together, that would work (kinda)... Then again, scouting isn't restricted to the pits, all of the scouting I directed was in the stands, except a total of one minute at the scores and results display. Luckily you don't need Wi-Fi for the stands, you are staying in one place. Or at least I didn't.
N also supports 5Ghz according to the standard, but idk if it requires special configuration, or if devices even support the channel, some types of antennas have to be built differently for different frequencies.
Unread 16-06-2008, 02:23
AKA: Eric Haskins
I don't disagree 802.11a would be the practical choice based on interference, but there are othe issues with 802.11a.
My big issues with 802.11a are that relativily few computers have 802.11a cards, and 802.11a has limited bandwidth, which could limit possible uses(video streaming maybe).
I think very few people want wireless programming in the pits. The concern I have is that if this type of rule were enforced it would prevent many of the scouting and collaberation systems teams have delevloped from being used.
And your other point, "why a debate over a nonexistent rule?". Its summer, we're not building robots, and we're geeks. What else are we supposed to do?
Eric Haskins KC9JVH
Unread 16-06-2008, 02:25
NickE's Avatar
_
Sounds expensive, but anyway...
Yes, N can also be configured to run on the 5ghz band. However, as time goes on, more and more devices will likely start using 802.11n, whereas 802.11a is probably not prone to nearly as much expansion (and interference)
[IMG] code is Off
Wireless Networks: Connecting buildings together KTorak IT / Communications 1 29-03-2005 20:41
Wifi Networks Eugenia Gabrielov Chit-Chat 4 17-06-2004 09:56
wireless internet at competitions? Jeremy_Mc General Forum 0 14-01-2003 14:37
So when will all these TV networks start noticing FIRST archiver 2001 4 24-06-2002 03:39
Seeking other NORTEL NETWORKS Teams - #'s 296, 408 & 437 archiver 2000 3 23-06-2002 22:41
